NEED INFO HELP!!!!!!!!!!!!! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-03-2011, 02:06 PM Thread Starter
Date registered: Apr 2011
Vehicle: 1997 mercedes E 420 (42000 miles and flawless)
I just bought my first car in 14 yrs.(i am old and ride bikes)----it is a beautiful 1997 one owner E 420 with 42K----BRG/palomino-----------everything is perfect, but, i donot know what lights etc are up front.----there are 2 that look like headlites(one is bigger and has Xenon lights ----the other has reg bulb). then a light down in the front bumper. THE QUESTION i have is, what is that little doorlike panel between the 2 headlight looking lights???????-----it says i have foglights ---WHERE??? i have owned mercedes way back--SIMPLE SL 450s!!!---------------would appreciate any help. thanks for your time. doug
bkrdoug is offline
post #2 of 6 (permalink) Old 04-03-2011, 03:33 PM
Date registered: Dec 2010
Vehicle: 2002 C230 Kompressor
If your car came with an owner's manual, it will do a good job of pointing all that out. If not, pop in to mbusa.com and your can either order or download a manual--great place to start.
The smaller lights low in the bumper will be your fogs. When you have low beam headlights on, you can pull the light switch out to turn on the fogs. Try it, then get out to look. If you flip your high beams on--fogs should turn off.
If i read your question right--the little panel between the lights (if below) might be headlight washers.
Unless the original light fixtures have been changed, your headlights are likely halogen (not xenon). If so, probably an H7 bulb--but know what you have before you try to change it.
Good luck,
earl
greenacres2 is offline
post #3 of 6 (permalink) Old 04-03-2011, 04:31 PM Thread Starter
info
EARL---i do have a owners manual and have read it twice,however, it does not address that panel or have a schematic of the car with proper IDs of everything. IF the big lights are the headlights what are the smaller lights?? they must be some kind of parking or driving lamps??----------i dont know how those panels could be a wiper or washer!!---------thanks doug
bkrdoug is offline
post #4 of 6 (permalink) Old 04-04-2011, 05:57 AM
The fogs look to be low in your bumper. Smaller round headlights are most likely High beam or Daytime Running Lights.
That little panel between the headlights is the headlight washer. On my car it is operated (or will be when i set aside the time to repair it) by the pneumatic pressure of the washer fluid. The switch is most likely a push-button near the light switch, perhaps in the upper right corner of the light switch panel. Good luck.
earl
post #5 of 6 (permalink) Old 04-04-2011, 09:10 AM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
In addition to what the above poster said, be sure to check out your cars specific forum.
If you do a search there, you can probably find all the information you need.
W210 E-Class - Benzworld.org - Mercedes-Benz Discussion Forum
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
post #6 of 6 (permalink) Old 04-04-2011, 10:27 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Ditto to 1984babybenz. You have what is commonly referred to as the orphan W210. 1997 was the only year MB made it. There are several helpful fellow owners on the W210 forum. Plus we have an extensive number of stickys that will help you quite a bit.
Musikmann is offline
Tell me some info about Mercedes Mechanics, salary info wiper General Mercedes-Benz 15 01-23-2014 11:24 PM
"No leak" product info & Tire info phil b R129 SL-Class 0 11-09-2007 11:43 AM
Misc info, MB's production plants and other info.... bgoin R170 SLK-Class 3 03-13-2003 09:54 AM
MBUSA web site info - seeking older ML info pmo W163 M-Class 6 02-28-2002 07:00 PM
info on future meceredes amg models and enginee info Guest (MBNZ) W210 E50 AMG, E55 AMG 1 05-29-2001 04:00 AM
