Air getting into fuel system 1983 300SD - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-01-2011, 06:53 AM Thread Starter
Date registered: Mar 2011
Vehicle: 1983 300SD
I have a 1983 300SD. I have a problem with air somehow getting drawn into the fuel line which prevent it from starting. I can get the car started by loosening the bolt on top of the fuel filter cannister, pumping the hand primer pump, and cranking the engine a few times which bleeds the air out of the lines. The car runs fine after that and will restart. But if if I let the car sit over night, air gets into the fuel system and won't start. I have replaced the hand primer pump and the fuel filters are not that old. Any suggetions on what might be causing the problem?
thanks for reading,
Mark
MarkeeP is offline
post #2 of 2 (permalink) Old 05-15-2013, 06:04 PM
Date registered: May 2013
Vehicle: 1982 300SD
Hey Mark, you are describing my exact problem, i have replaced the primer pump as well, with no avail to solving the problem, car runs fine at med rpm's, (75mph) but when i try to get it to idle, it soon begins choking it seems on air, prefilter has a bit of air but i thought that was normal....? as long as i bleed it before starting, it runs fine. Did you fine any solution? I would appreciate some advice.
thebenzboy is offline
    INSTALLING COLD AIR INTAKE 300sd 1983 mercedes Ilovemycar W126 S,SE,SEC,SEL,SD,SDL Class 10 10-20-2010 06:30 AM
    Can't find my fuel system air leak Stevenpfaff W123 E,CE,D,CD,TD,TE Class 8 07-06-2006 11:32 AM
    air in fuel system quayhog W123 E,CE,D,CD,TD,TE Class 3 09-13-2005 07:01 AM
    300sd fuel system problem cajuncody372 General Mercedes-Benz 3 11-28-2004 06:25 AM
    Having problems with my 1983 300sd brake system jgolem General Mercedes-Benz 4 04-12-2004 07:22 PM
