how much labor to replace camshaft/crankshaft position sensor - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 03-30-2011, 07:49 PM Thread Starter
Date registered: Mar 2011
Hi, I'm new to the forums. I stumbled upon this forum as I was searching online for information regarding camshaft and crankshaft position sensor replacement. I was charged 3.8 hours ($120/hr) at my local Mercedes-Benz dealership to replace one camshaft position sensor and one crankshaft position sensor in my 2005 ML550 V-8. My SUV barely has 40K miles on it.
My question is:
1) Is 3.8 hours a little too much?
2) What is the typical # of hours necessary to replace one camshaft position sensor and one crankshaft position sensor?
I believe I may have been overcharged and would like some of your opinions before I call my dealership regarding this. Does anyone have any advice in how I should handle this? I appreciate any help you can provide.
ml550driver is offline
post #2 of 13 (permalink) Old 03-30-2011, 08:19 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
I replaced the crank shaft sensor once. If I have to do it again, it probably will take me 10 minutes.
mbvis is offline
post #3 of 13 (permalink) Old 03-30-2011, 08:23 PM
eric242340's Avatar
Quoted: 307 Post(s)
To do both will take approx 20 minutes but most workshops will charge an hour. 3.8? I could take the engine and transmission out in that time
ERIC.
eric242340 is offline
post #4 of 13 (permalink) Old 03-30-2011, 08:38 PM
mbvis's Avatar
Quoted: 2 Post(s)
The first time is always the hardest even though the W210 stickies explain a lot.
Locating the sensor, determining the type (one tab, two tabs), order the part, getting the right tool, remove, install, test) took me several hours and some scratches on the arm.
mbvis is offline
post #5 of 13 (permalink) Old 03-30-2011, 08:44 PM
eric242340's Avatar
Quoted: 307 Post(s)
But that is a DIY, official labour time for both is less than 1 hour and he had the job done at a Dealer (Stealer rather).
ERIC.
post #6 of 13 (permalink) Old 03-30-2011, 08:48 PM Thread Starter
Thank you all for your replies. I really appreciate it. I have already paid the dealer ~$900 for parts + labor today and the shop is already closed. I had no idea that I was being overcharged. Is it possible to recover any of the costs? I really do no think I should have been billed 3.8 hours of labor. Can I dispute these costs? Or is it hopeless?
post #7 of 13 (permalink) Old 03-31-2011, 09:23 AM
mbvis's Avatar
Quoted: 2 Post(s)
You can call other dealers to get a quote for the same work to compare. I doubt that you can dispute any charge after you signed the work order.
Just to know why some people call dealer stealer. The crank sensor is priced about $50 for online order. Look for it on the itemized bill. But the dealer got to pay lease for a big lot, salaries of black tie white shirt advisers, blue shirt mechanics, free cappuccino, leatherette seating in air conditioned lounge, free Wifi, etc. Think positive, you're going negative $900 to help the local economy.
mbvis is offline
post #8 of 13 (permalink) Old 03-31-2011, 11:22 AM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Most of replies compare the CPS replacements to sedans.
I did CPS replacement on ML55 and top access was impossible. I had to lift the truck, remove the wheel, inner fender and few heat shields.
That was few years ago, but I don't think it took more than 2 hr even I was figuring out what I was doing.
If Erick's quote for 1 hr is correct and the shop charged you for over 3 hr, you have the edge for complain, but also burden of prove.
Kajtek1 is online now
post #9 of 13 (permalink) Old 03-31-2011, 07:16 PM Thread Starter
Thanks for all the replies. Do you think I have a legal case against this dealer?
I found the labor guide pdf and it says that the camshaft position sensor replacement should take 0.5 hrs and the crankshaft position sensor should take 0.6 hours. The sum is 1.1 hours. I was charged for 3.8 hours ($120/hr) by the dealer. Isn't that fraud?
post #10 of 13 (permalink) Old 03-31-2011, 10:09 PM
Kajtek1's Avatar
Fraud is strong word. Did they call you with estimate and you agree to it?
This way, or the other, the call to MB USA with complain is not going to cost you much.
    Crankshaft Position Sensor / Camshaft Position Sensor to3033 W140 S-Class 4 03-26-2010 12:15 PM
    how to replace camshaft position sensor on a S600 ? René S600 W220 S-Class 0 01-25-2010 05:31 AM
    Bi-Polar Benz - CPS/KPS Camshaft or Crankshaft position sensor?? kickinitin703 W210 E-Class 3 12-02-2009 04:25 AM
    Camshaft vs. Crankshaft position sensor missinlinc C208/A208 CLK-Class 3 10-17-2007 12:32 PM
    Crankshaft/camshaft position sensor??? mbj898 W210 E-Class 7 07-21-2007 12:29 AM
