Hazard Relay 1980 450SLC question(s) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-30-2011, 09:43 AM Thread Starter
Date registered: Mar 2011
Hi there.
I am new to this forum and new to the world of MBZ repair. I have two questions and any help would be appreciated.
Question 1:
I need a new hazard relay and the one I found on partsgeek.com 80 1980 Mercedes 450SLC Hazard Flasher Switch - Body Electrical - OES Genuine - PartsGeek has 5 pins on the right side, while my old one has 4 pins on the right side (see attached). Can I still use the new five pin hazard relay even though the "extra" pin will not make contact with any wire?
Question 2:
Does anyone have a wiring diagram for the "receiving / female end" (don't know terminology) for the hazard relay? I accidentally popped off the backing and think I got it right, but am not positive. I know...I probably shouldn't start screwing around if these are the types of mistakes I'm making, but you gotta learn somehow right?
any help would be appreciated,
ID:	366461   Click image for larger version
mathiastwo is offline
post #2 of 2 (permalink) Old 10-24-2011, 09:09 AM
Date registered: Jan 2010
Vehicle: 81 380SL
I have the same problem, did you ever get an answer or figure hout how to hook up the new flasher relay?
chris_cpa is offline
    1980 240d glow plug relay question ChrisBillawala W123 E,CE,D,CD,TD,TE Class 11 11-13-2010 06:36 AM
    I need help with 1980 500se, fuel pump relay question CivicTuning2 W126 S,SE,SEC,SEL,SD,SDL Class 8 06-03-2010 04:00 PM
    Where is the Hazard Light Relay Wayne4756 W124 E,CE,D,TD Class 2 11-14-2009 06:33 AM
    Interested in used hazard relay Donald R129 SL-Class 0 05-22-2005 05:30 AM
    Interested in used hazard relay Donald R129 SL-Class 2 05-10-2005 12:25 PM
