New K56 batt cut-off didn't help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-25-2011, 05:59 PM Thread Starter
Date registered: Mar 2011
Any help with the known K56 battery cut-off relay problem on 98 SLk230 ??
I replaced the batt and alt before realizing they weren't the problem so both test good. After I replaced the battery cut-off relay, nothing changed. The "G" post on the relay has 19+V and the "battery" post has 12.2V (less with the lights or other stuff on).
In other words, the relay is not passing the charge on to the battery even though the alternator is maxed.
Anyone know where the signal comes from that throws the relay off? Could a false crash detection signal from some inertial switch have blown the new relay already? If I just jumper around the relay will the regulator still control the charging level so I dont fry my battery? I don't really care if I'm a tiny bit less safe in the event of a crash, I just want to be able to drive without wonderingwhen my battery will go dead in traffic.
Ernie
erniel2 is offline
post #2 of 2 (permalink) Old 03-25-2011, 06:32 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Try asking in your cars specific forum, you are more likely to get more answers there.
R170 SLK Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
    Batt. memory keeper gw17625410 W163 M-Class 1 07-08-2010 09:45 PM
    PSE drains batt CalJeep C208/A208 CLK-Class 0 04-13-2010 10:07 AM
    confused-- batt/alternator or ? skin6061 W124 E,CE,D,TD Class 2 04-18-2009 07:22 PM
    Batt. Light Confusion mssdoglover W126 S,SE,SEC,SEL,SD,SDL Class 6 02-14-2007 04:17 PM
    can i replaced the batt for the wireless key on my own? HotGQ161 W203 C-Class 5 05-26-2004 09:15 PM
