HELP PLEASE - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-25-2011, 04:05 PM Thread Starter
Date registered: Mar 2011
Unhappy HELP PLEASE
i own a 1991 300E, within the last few weeks its decided that it doesnt want to start sometimes when you turn the car on. i spoke with my machanic and he has tried a few differnt things to fix the problem but nothing has fixed it. what the car is doing, is that when you go to start it, it wont turn over at all, all of the the electronics work just fine on the car but it wont attempt to turn over at all. I've noticed that it will do this about once a week and when it does act up it will not turn over for about 3 hours later, as of today, the NSS has been replaced, the tester contral box has been replaced, the crank sensor has been replaced and the control overload relay has been replaced and none of these replacements have fixed the problem, does anyone have any sort of feedback or ideas as to what the problem could be, any information would be great!
blackbaby91 is offline
post #2 of 2 (permalink) Old 03-26-2011, 12:38 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome aboard. Please click user cp and edit details to add your vehicle and location to your profile, it's useful information.
You own a W124, so you're likely to find better information in that car's forum, which is down the page in the sedans section. Here is a link you can use for now: W124 E,CE,D,TD Class - Benzworld.org - Mercedes-Benz Discussion Forum
Rather than just reposting, may I suggest that you take a few minutes to use the search function or look through the stickies at the top as there is a wealth of information already there?
Good luck.
Check Codes is offline
