2005 C230 Sport Kompressor owner with A LOT of probs. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-24-2011, 02:44 PM Thread Starter
Date registered: May 2010
Lightbulb 2005 C230 Sport Kompressor owner with A LOT of probs.
HI, my name is Danny. I reside in Glendale, Arizona USA. I have owned a used 2005 C230 Sport Kompressor Sedan 6 speed supercharged 4 cylinder going on 3 years now and as of now I regret buying a Mercedes Benz. I have had better luck with Hyundai's. It drove fine until just outside of warranty.
I hope meeting new members I can get some advice and learn some tricks of the trade so I can fix most of the problems myself.
I am a custom car builder and custom air brush/painter.
I have built some big block Pontiac motors as well as small block Ford motors. But I NEVER thought I might have to tear into my Mercedes Benz.
- As of now I am missfiring in Cylinder #2. I tool it to the dealership and I was told that the valve seats in combustion chamber #2 failed and I have lost compression in that cylinder due to this. Compression tests and flow tests confirmed this. #1, #3, #4, cylinders are good, but I am told that the head will have to come off and I will have to get it rebuilt. OF course I was 6000 miles outside my warranty!! And I can't pass emissions!!!
The stealership wants $4000 to do the work, but the economy is bad and of course money is tight. I am sure I can do it myself. But I need some inside info and advice.
- The steering column lock is busted as well, I went to adjust it one day and POP it busted.
- The rear pop-up shade in the rear window is stuck in the up position and it sux driving at night.
- The top portion of the passenger side door handle busted and I have to be careful when closing that door.
- The driver side window motor failed and the window just drops and I had to open up the panel and prop the window up
I hope to find some knowledgeable friends here.
2nd Runner is offline
post #2 of 3 (permalink) Old 03-25-2011, 06:07 AM
eric242340's Avatar
Quoted: 300 Post(s)
Welcome to Benzworld Danny. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 12-04-2011, 02:04 PM
Date registered: Sep 2011
Vehicle: 05 c230 kompressor
Send a message via AIM to Chau619 Send a message via Skype™ to Chau619
i have the same problem on my 05 w203 about the rear pop up shades being stuck at the up posistion. what i did was holding the "down" option and have a friend gently guide it down. it works for me now w/o the extra help but i think the motor is stuck on the inside. are you knowledgable about electronics or motor/controllers? you can investigate this problem..its pretty simple.
Chau619 is offline
    2005 C230 Kompressor Owner nickantala General Mercedes-Benz 3 12-08-2010 07:57 PM
    2005 C230 Sport Kompressor - Tire Choice??? jasonisgr8 W203 C-Class 11 02-28-2010 02:08 PM
    C230 Help in-dash mounting after market stereo 2005 C230 Kompressor Sport kmm2234 Audio & Telematics Forum 1 07-29-2009 11:24 AM
    2003,2004, 2005 c230 kompressor sport... butler W203 C-Class 9 01-24-2008 12:41 PM
    2005 C230 Kompressor Sport help, thanks ctatay General Mercedes-Benz 9 12-21-2005 10:08 AM
