Ml 320 SRS warning light - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-23-2011, 01:45 PM Thread Starter
Date registered: Mar 2011
Recently was working on fender mounted turn signal light. In process I disconnected the power multi plug ,located in the door jamb,for all elictrical items in the door.
In doing wire continuity chet for turn signal wiring, I turned the ignition key to position 3. When I turned the ignition key back to 0 I noticed the SRS warning lamp lit. After re-connecting the door power plub the SRS light remained on.
Can this Trouble be diagnosed with and reset with OBD II?
FEK is offline
post #2 of 2 (permalink) Old 03-23-2011, 02:33 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
I believe it can be reset with some OBDII scanners.
1984babybenz is offline
    Srs Warning Light Johan12fly V-Class 18 07-16-2013 10:50 AM
    SRS warning light on blackjack21 W203 C-Class 3 01-25-2008 08:37 AM
    SRS Warning Light AxelWulff W126 S,SE,SEC,SEL,SD,SDL Class 8 02-10-2006 02:55 PM
    SRS Warning Light Brecon W210 E-Class 0 06-01-2003 03:31 AM
    SRS WARNING LIGHT jeffsf W124 E,CE,D,TD Class 6 08-16-2002 10:52 AM
