w210 - 2001 - how to change steering-fluid? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-20-2011, 06:17 AM Thread Starter
Date registered: Mar 2011
when i drive with my car there is some sound on the steering.
So i think that i need to check steering-fluid.
But where can i found it ? does any body have any picture about wheren i can find the place ?
Itw mercedes w210 (e200) from 2001 ..
nasar is offline
post #2 of 3 (permalink) Old 03-20-2011, 09:26 AM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Look in your owners manual, it should say there.
If not, take a look in the w210 forum.
W210 E-Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
post #3 of 3 (permalink) Old 03-20-2011, 10:54 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Ditto to checking the W210 forum and look in the sticky threads. There are a lot of do it yourself threads and I'm pretty sure there is one for that in there. The sound could come from a couple of places; like the common gasket in the rack and pinion steering, to the power steering pump, to low fluid level. It might even be the rack going bad but I hope not! If the fluid is low, you'd better look for a leak.
Musikmann is offline
    Power Steering Fluid Change misterkennedy W123 E,CE,D,CD,TD,TE Class 21 12-09-2014 11:58 PM
    2001 C320 Transmission Filter/Fluid Change everycredit W203 C-Class 12 10-26-2009 01:31 PM
    (HELP) Power Steering Fluid Change Starglider W220 S-Class 4 03-11-2007 02:57 PM
    Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
    steering fluid leak W210 HELP philly W210 E-Class 0 03-24-2005 08:58 AM
