I used to love my mercedes c280 before she got sick - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-19-2011, 07:11 PM Thread Starter
Date registered: Mar 2011
Vehicle: 1997 Mercedes C 280 Sport
I have a 97 c280 sport and had a leak at the pilot bushing. I replaced the pilot bushing as well as the fluids from the pan and torque convertor. Also replaced the filter and gasket. I used the MB transmission fluid at $14 a pop. During the job I unplugged the 13 pin connector before emptying the torque convertor. I didn't have a 27mm socket so I was trying to get lucky and have the torque conv. drain plug come to the opening (which didnt work). The next day I got the socket and removed the plug and completed the job. When I went to start it I noticed the engine check light came on. Got my odbcII scanner and wrote down the faults then erased them. The car only works in second or reverse. When shifting it jolts quite hard. I di take a voltage meter down to the pilot bushing plug and some pins had 12 volt or greater. Does this need to be taken to the dealer. I read on other forums that it just may need a reset.
it reads codes p0753, p0743, p0763, p0758 the 743,753 and 763 are solonoids. the 758 is torque converter electrical.
skooner is offline
post #2 of 4 (permalink) Old 03-19-2011, 07:31 PM
Kajtek1's Avatar
Quoted: 1191 Post(s)
Not familiar with your model, but generally transmission codes will not clear with OBDII scanner. For that you need Star of Carsoft computer.
Fill up your profile with location and maybe you will find local member with the right tools that might help you.
Good luck.
Kajtek1 is online now
post #3 of 4 (permalink) Old 03-19-2011, 07:39 PM Thread Starter
Special Scanner Tool
Do the Snapon Scanners (typically found in automotive shops) have this function necessary? Greatly appreciate the help!!!
skooner is offline
post #4 of 4 (permalink) Old 03-19-2011, 08:09 PM
Kajtek1's Avatar
Snapon is brand name, not the function of the scanner.
The Star compliant scanner are pretty rare. Even our local AAMCO shop didn't have one and other shop quoted me $120 just for reading the codes.
    1994 C280 Love my car! Lena Johnson General Mercedes-Benz 1 04-14-2012 12:31 PM
    Benzie's sick again... 1995 C280 CE Light MorbidBarbie W202 C-Class 10 10-03-2010 12:55 AM
    I'm sick of Mercedes :( Courage W164 M-Class 2 01-13-2009 02:23 PM
    Sick Of BMW...Always happy in Mercedes The andrew General Mercedes-Benz 2 10-10-2008 05:36 PM
    "Sick" of the Mercedes S-Class. Please help! Petrarch W140 S-Class 12 10-03-2005 01:07 PM
