scared to pass - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-19-2011, 11:35 AM Thread Starter
Date registered: Apr 2008
Vehicle: 1987 300TD, 124, 175M miles
scared to pass
I have a 1987 300TD. When I'm doing highway speeds, and need to pass someone, I have to allow a long shot of road to get around someone. I did a purge of my pump, and put in a new primary and secondary fuel filter, but it runs the same. Any thoughts?
beathoreau is offline
post #2 of 4 (permalink) Old 03-19-2011, 09:15 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Are the injectors original? Fuel clean?
Try doing a search for other options in the w124 forum.
1984babybenz is offline
post #3 of 4 (permalink) Old 03-19-2011, 09:20 PM
Kajtek1's Avatar
Quoted: 1195 Post(s)
I remember the engine is about 130 HP rated. Don't know factory data, but I would expect it to make 0 to 60 in about 12 seconds or less. What is your time?
Kajtek1 is offline
post #4 of 4 (permalink) Old 03-22-2011, 09:17 AM
JBurdon1270's Avatar
Date registered: Oct 2009
Vehicle: 1978 300D - sold, 91 300TE 4Matic - sold, 1982 300D
I would suspect skewed injection pump timing due to timing chain stretch if you have a high milage car that has an older timing chain. I'm not sure if 87's have an ALDA (like on the OM617), but the lines coming from it can become clogged and will limit boost. It results in loss of power and having to really put your foot down to get the car moving, especially from a standstill.
I had the timing chain stretch issue on my old 78 300D and after I adjusted the IP timing (and the valve clearance, your car has hydraulic lifters so it's not an issue) I was shocked at the improvement. A turbo diesel should have no problem passing at speed, they're just a little slow under 30mph...
JBurdon1270 is offline
    I'm Scared abiby R/C107 SL/SLC Class 14 07-12-2010 01:02 AM
    RFID: scared yet? benz rider Off-Topic 7 10-04-2009 05:00 PM
    scared of battery.... mista R170 SLK-Class 5 09-22-2009 06:16 AM
    Scared Kid snips Off-Topic 8 02-14-2006 09:55 AM
    Im scared. What could this be? :| Andrew T. W124 E,CE,D,TD Class 18 06-23-2003 03:57 PM
