Substitute break lights - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-17-2011, 08:44 PM Thread Starter
Date registered: Mar 2011
Question Substitute break lights
I got a 2006 ML350. I had to change the substitute break lights on the left and right side both. The Mal-Functioning messages on the console keeps coming back once in a while and then goes away after a while. What could be the issue and resolution?
PopEye1332 is offline
post #2 of 3 (permalink) Old 03-18-2011, 08:30 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Break = broken
Brake = stopped
Just replace all the bulbs and you should be fine. PepBoys bulbs may not, however, as this is a European car that prefers Euro-spec bulbs.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 03-18-2011, 01:31 PM
They can be a pain. you just have not found the bad bulb yet. I helps if you can have some one step on the brake and you look at the lights the good one will light for a split second then it will go to default system. Good Luck
Stick999 is offline
    95 style break lights on 92 car russianwol W140 S-Class 3 08-21-2009 01:13 PM
    ML350 2006 break lights trigital W164 M-Class 0 07-22-2009 06:48 AM
    no cruise control, no break lights! deejaykaygee1 W163 M-Class 10 08-28-2006 08:10 AM
    Both break lights not working MarkR170 R170 SLK-Class 1 05-21-2006 03:33 PM
    ML55 Break lights kia W163 M-Class 2 11-18-2004 01:19 PM
