Vito 108 cdi will not rev over 4500 after clutch pressed - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-17-2011, 02:03 PM Thread Starter
Date registered: Mar 2011
Vehicle: vito 108 cdi
hi all. ive got a mercedes vito all but an old one. seem to have a problem with edc light coming on under load, mainly in 5th gear. also oil warning light on constant.
does not rev over 4500 when driving or clutch pressed
i got myself picked up by the aa with an awful knocking sound from engine.
had a bit of work done recently ie 2x new injectors 2x injectors reseated.
after this work was bit of an deisel leak on rocker cover and drain was blocked so fuel flowed mainly down side near turbo inlet pipe.
the fault codes that wont clear are.
1188 3RD CUT OFF PISTON
0520 Engine Oil Pressure Sensor/OPEN SHORT CIRCUIT
engine seems to make different noise and starts & stops with a chug also blowing a bit of oil out.
could the (3RD CUT OFF PISTON resistor ground fault) cause edc light to come on or would it be more like the other 2 injectors???
please help???
Bobby...
GREASED MONK is offline
post #2 of 3 (permalink) Old 03-17-2011, 06:38 PM
eric242340's Avatar
Quoted: 312 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 03-18-2011, 12:16 AM Thread Starter
Hi Eric will do
vito 108 cdi wont rev over 3000rpm tripod23 V-Class 4 11-19-2011 03:48 AM
My 108 CDI Clutch ? jayiow V-Class 3 07-14-2010 08:48 AM
Vito 108 Starts but won't rev past tick over The Search V-Class 6 03-20-2009 07:21 AM
Vito 108 CDi fastflyer99 V-Class 2 04-17-2007 03:18 PM
Vito 108 CDI bob the lawn V-Class 2 04-10-2005 04:11 AM
