h.i.d kit - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-16-2011, 08:59 PM Thread Starter
cain kompressor's Avatar
Date registered: Mar 2011
Vehicle: 04 c230 kompressor
h.i.d kit
i wanna add these to my 04 c230 kompressor but was told not to cuz it can cause a malfunction at all times?any tips?
cain kompressor is offline
post #2 of 2 (permalink) Old 03-17-2011, 06:28 PM
StarPower's Avatar
Date registered: Oct 2009
Vehicle: 2003 Lincoln LS V8
A dealership or independent can reprogram your computer to enable HIDs. This should eliminate the error message, depending on how your HIDs are wired. You may still get an error message if you use an aftermarket rebased kit, especially with a relay harness.
That said, the rebased kits that fit a HID bulb into your halogen projectors aren't the best option. The characteristics of a HID arc are very different from a halogen filament, and even if the arc is in the correct position (which it usually isn't) the optics of your halogen projectors won't focus the beam properly.
If you really want to add HIDs, the best way would be to replace your halogen projectors with HID projectors. Since these were an option on the C-Class it's pretty easy to do. Also, if you use the stock wiring, you can be guaranteed not to get error messages as long as HIDs are enabled in the computer.
StarPower is offline
    WANTED: '97 C280 lip kit or brabus body kit BG_Benzo27 For Sale/Wanted/Trade/Giveaway 0 07-30-2007 01:59 AM
    in search of a 16v kit or amg kit for facelift w201 sunstealth W201 190-Class 14 04-17-2007 07:12 PM
    Help installed aftermarket HID kit in 04' CLK and the kit wigs out and.. 1FastS4.com C208/A208 CLK-Class 4 02-01-2007 03:58 PM
    Help installed aftermarket HID kit in C32 and the kit wigs out and.. 1FastS4.com W203 C32 AMG, C55 AMG 3 02-20-2004 08:25 AM
    FS: Authentic Carlsson Body Kit (Aero Kit) for CLK 320 Under Pressure C208/A208 CLK-Class 2 07-06-2003 01:18 AM
