Leaking Trans Fluid - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-15-2011, 11:55 AM Thread Starter
Date registered: Mar 2011
Vehicle: 2003 C230 Kompressor
Leaking Trans Fluid
Hi,
I am new here, I was wondering if anyone had a DIY video or something to help me with my car, I have a 2003 C230K and it appears to be leaking transmission fluid at the 13 pin trans connector not sure if it is an O-ring or not and i do not know what size O-rings i would even need, I appreciate any help/advice.
DYNOMITE is offline
post #2 of 8 (permalink) Old 03-15-2011, 12:24 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Check out your cars designated forum. There is probably a diy there.
W203 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
post #3 of 8 (permalink) Old 03-15-2011, 01:46 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by DYNOMITE View Post
Hi,
Please click user cp and edit details to add your vehicle and location to your profile, it's useful information.
If it's leaking, new o-rings are not the solution (nor are they separately available). The part (connector/spacer/adapter/pilot bushing) has been superseded, it's cheap (under $15 even at a greedy dealer) and easily replaced. Check the DIYs and FAQ thread in the W210 section, it's the same setup for your car and excellent info with pics.
Good luck.
Check Codes is offline
post #4 of 8 (permalink) Old 03-15-2011, 01:57 PM Thread Starter
Thanks Gregs and babybenz!
I am confused to the suggestions as to the proper forum. W203 seems to be for my car however I am still searching for a topic that covers my current situation. And W210 Seems to be an E-Class forum, are you saying that the E-class AT is the same as my C-Class?
DYNOMITE is offline
post #5 of 8 (permalink) Old 03-15-2011, 02:00 PM
Quoted: 35 Post(s)
That is exactly what I am saying. You'll also find it in the S class, roadsters and ML and GL. Clear across the lineup.
And the W203 is the specific forum for your car, but transmission stuff in the 210 section is better IMHO, so for right now plumb the depths of the detailed knowledge you need.
This is the FAQ thread I referenced, it links to a bunch of others:
http://www.benzworld.org/forums/w210...ssion-faq.html
post #6 of 8 (permalink) Old 03-15-2011, 02:04 PM Thread Starter
Thanks Gregs, I appreciate your feedback!
DYNOMITE is offline
post #7 of 8 (permalink) Old 03-15-2011, 04:02 PM
Date registered: Dec 2010
Vehicle: 2002 C230 Kompressor
You'll also find that same tranny adapter in the Sprinter and Plymouth/Chrysler Crossfire lines--both use the 722.6 transmission. After waiting 3 days for my adapter to arrive, i found i could have bought the exact same thing at the Chrysler dealer here in town for like $9.00.
It wasn't the time or money that bothered me--it was missing the chance to buy something for my car right here. Shoot, i can't even find air for the tires locally!!
earl
greenacres2 is offline
post #8 of 8 (permalink) Old 03-16-2011, 11:05 AM Thread Starter
I picked up the adapter yesterday at the MB parts dealer near my work for $12. not too worried about the price difference, I am fortunate enough that there is a MB parts dealer nearby!
DYNOMITE is offline
    Trans Leaking.. well from everywhere 900$sel W126 S,SE,SEC,SEL,SD,SDL Class 3 07-28-2010 05:08 AM
    Verify correct alternative Trans Fluid for 722.623 trans ??? Pancho C208/A208 CLK-Class 10 02-08-2010 10:11 AM
    Leaking trans scsponger31 W203 C32 AMG, C55 AMG 1 12-27-2009 07:52 PM
    Trans fluid leaking..help... Ridingdirty230 R170 SLK-Class 12 12-26-2007 04:36 PM
    trans fluid and diff fluid replacement cost? numitor R170 SLK-Class 10 07-28-2007 09:40 PM
