97 S500 Blower motor help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-12-2011, 02:21 AM Thread Starter
Date registered: Mar 2011
Hey guys, I have a 97 S500 with no blowing air. I tested the relay and it's good, so I took the motor out and got a new one, but now I need to get the impeller blades off. How can I do this? The old motor shaft is pretty well rusted and is incredibly hard to turn. I've let it soak in liquid wrench for a day now, but still nothing. Tried a hammer to tap it loose, and I tried to drill through the center of the shaft, but ti's hardened steel. Any ideas?
Waveripper308 is offline
post #2 of 2 (permalink) Old 03-12-2011, 10:01 AM
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL, 1999 S500
First, you should ask this question in the W140 section, which is your car. You need to set the squirel cage up on something to get the motor off the ground and use a hammer and drift to knock the shaft out.
chuckindetroit is offline
    Blower not working but blower motor fine what to check next? classicchic W123 E,CE,D,CD,TD,TE Class 20 05-07-2014 05:56 PM
    1998 W210 E300DT Bad Blower Regulator or Blower Motor?? How to tell DieselNuts W210 E-Class 12 08-16-2012 09:32 AM
    Blower Motor + Burning Smell = No Blower Motor nuts2that W210 E-Class 6 07-28-2010 01:07 AM
    1996 S500 blower motor relay JPool W140 S-Class 6 08-06-2009 07:41 PM
    where can I get an ac blower motor for my 1995 s500 ?? RUTV S500 W140 S-Class 12 09-03-2008 08:59 AM
