Hi! to all - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-10-2011, 12:53 PM Thread Starter
Date registered: Mar 2011
Vehicle: 1988 560SL @ 94K
Hi! to all
Proud owner of a 1988 560SL! I live in Macon (Lizella actually, but not even a caution light) GA. This site has been a godsend already. Loose steering-was going to replace gearbox or have shop do ...however now just need the coupling. Am also working to resolve some AC issues. Center vent flow diagnosis is in process-hope it's not the dreaded hidden pods. I haven't been able to find info on a separate AC issue I'm having: Aside from stated center flow issue, everything seems to be "cool" then AC stops/fan stops. I can sometimes cycle the manual fan control buttons and it comes on for a little while-then back to same issue. Having refrigerant topped off didn't seen to help. Problem is intermittent-sometimes takes 20-30 minutes to occur. Help!
MichaelAW is offline
post #2 of 2 (permalink) Old 03-10-2011, 08:38 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
eric242340 is offline
