BAD IDLE AND DRIVABILITY - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-10-2011, 11:31 AM Thread Starter
Date registered: Mar 2011
Vehicle: White 1990 300ce 24v. 3.0 DOHC 6
1990 300ce 24v. 3.0 6 First let me start off saying this car has 220.058 miles on it and it has bee sitting up sense 2007. i'm trying to get it back and road worthy, however it would not start and stay running, so i have changed the two fuel pumps and filter, fuel regulator, distributer plus the module, and six new spark plugs drained the fuel tank of the old smelly 4 year old gas, and adjusted the distributor air/fuel mixture. The car starts and stays running but with a rough idle and miss. when test driving the car drives strong with OK for about 15 minutes the performance starts to go down drastically the more i give it gas the less it wants to perform. if i attempt to get off the gas slightly it picks up if i give it gas it slows down until it is barely moving at all and then it stops. i turn off the key start it back um and it's bak strong again for a few more minutes. HELP PLEASE I'M SPENDING A GRIP OF MONEY IN THIS PIT.
eastsideclemeg is offline
post #2 of 3 (permalink) Old 03-10-2011, 05:05 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
If there's light (CEL - Check Engine Light) then get an OBDI reader to read the engine trouble code.
If there's no CELight, you will throw more money away in trying to blindly fix the car. Get rid of it.
mbvis is offline
post #3 of 3 (permalink) Old 03-10-2011, 10:15 PM Thread Starter
IT HAS NO CHECK ENGINE LIGHT SHOWING, BUT IT NEVER DID EVEN AT START UP WHEN ALL CLUSTER LIGHTS ARE SUPOSE TO TEST LIGHT AT START-UP ALL OTHER CLUSTER LIGHTS COME ON EXCEPT THE CHECK ENGINE LIGHT. MAYBE IT'S BURT OUT!
Noise and drivability issue Turbotony W203 C-Class 12 06-28-2010 06:00 PM
87 420sel High idle and bad hesitation/stumble off idle. Please help! marzban123 W126 S,SE,SEC,SEL,SD,SDL Class 18 07-10-2009 12:42 AM
bad idle, bad running conditions?? i dont know what to do.. abuck260e W124 E,CE,D,TD Class 3 03-03-2008 10:58 AM
bad emissions + rough idle @ 750 = no suck or bad engine? veryslowbenz W126 S,SE,SEC,SEL,SD,SDL Class 30 09-15-2007 04:05 AM
81 280sl, 2 drivability problems Gen3Benz R/C107 SL/SLC Class 3 08-05-2005 04:11 AM
