Thermoplastic clamps or traditional radiator hose clamps? - Mercedes-Benz Forum
View Poll Results: Would you use Thermal plastic hose clamps on your Mercedes?
Yes 1 100.00%
No way 0 0%
Don't know 0 0%
I will stick with traditional worm clamps 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
post #1 of 1 (permalink) Old 03-09-2011, 02:17 PM Thread Starter
jbrown1843's Avatar
Date registered: Oct 2007
Vehicle: 1999 SLK, and 2010 E-350
Smile Thermoplastic clamps or traditional radiator hose clamps?
Has anyone used the new Thermoplastic hose clamps yet for any radiator hose replacement jobs? Getting ready to replace all the hoses this weekend on the 1999 SLK and saw these being pushed by the auto parts houses - guess you just use a heat gun to shrink them on. Here is some info from the Gates website on their product.
Also if you don't know what these are you can watch the Gates product demo (produced for trucks) here
//start gates website info//
Thermoplastic Clamp Offers Maintenance-Free Hose Connection
A new cooling system clamp from Gates, made of thermoplastic, shrinks to conform to any shape of hose and housing.
Made of a heat-sensitive material, Gates PowerGrip™ SB clamp solves coolant leakage problems in both silicone and standard rubber wall hoses, even on out-of-round fittings.
Gates thermoplastic clamp maintains a dynamic tension so that it never needs retightening. Whenever the engine reaches operating temperture, the shrink forces of PowerGrip SB readjust to a consistent clamping force. In addition, its clamping force increases as the temperature drops below 40 degrees F, thereby tightening the connection.
Cold leaks, which normally occur when the temperature drops below 40 degrees F, are eliminated.
Installation using a heat gun is fast and easy, including hard-to-reach places. Heat-gun attachments permit installation in confining areas that would be extremely difficult to reach using a screwdriver on conventional worm-drive screw clamps.
The PowerGrip SB hose clamp features a smooth surface that won't rust, corrode, or result in cut fingers during installation. PowerGrip SB hose clamps are completely resistant to all automotive fluids including oil, antifreeze and even brake fluid.
Wider than conventional clamps, PowerGrip SB hose clamps can be positioned over the raised bead on the end of the fitting nipple - even cast metal.
PowerGrip SB clamps are readily removed with Gates' specially-designed clamp removal tool. The clamps also can be removed using a soldering iron to melt through the thermoplastic material.
Sizes are available for 1/4 through 3-1/8 inch I.D. hose.
jbrown1843 is offline
    screwless hose clamps. bass1175 W140 S-Class 14 04-18-2011 05:40 PM
    How do you deal with these fuel filter hose clamps on a W210? Blaine_S W210 E-Class 11 02-23-2009 08:04 AM
    F/S- W126 BEHR RADIATOR with hoses/clamps mr.xpowerseller For Sale/Wanted/Trade/Giveaway 2 11-16-2007 02:42 PM
    The clamps on the airbox in stock form are one time use clamps, you can cut them off... Dave OH R170 SLK-Class 1 09-05-2004 01:19 PM
    How to check your power steering hose clamps... Drew W163 M-Class 7 10-20-2002 02:11 PM
