Using starter fluid to start '82 300SD - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-09-2011, 10:45 AM Thread Starter
Date registered: Mar 2011
Vehicle: '82 300SD
Hi everyone, new to these boards, but have owned this 300SD since Sept '09.
This vehicle has been running fairly well these past, almost 2 years.
However, I have had to utilize starter-fluid this past week in order to get the engine to fire up.
Without the fluid, it just cranks away, but no ignition until applying the starter-fluid.
Could this be a fuel-filter issue, or are the glow-plugs not pre-heating properly, or a compression issue?
Note that when I drive the car some place, park it and leave it off for 20-30 min, it will start up right after.
Any longer than that, starter-fluid time!!!
bentstrider is offline
post #2 of 4 (permalink) Old 03-09-2011, 12:45 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
I would try replacing your fuel filter. Check if you are getting fuel when you first try to start it.
Also, posting in your cars specific forum will help you get more answers.
W126 S,SE,SEC,SEL,SD,SDL Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
post #3 of 4 (permalink) Old 03-09-2011, 03:07 PM Thread Starter
Vehicle: '82 300SD
I'll try both of those ideas out, see if it'll get me anywhere.
Thanks.
post #4 of 4 (permalink) Old 03-09-2011, 03:36 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Sounds like GP issue to me.
Shouldn't take longer to put a tester on it, than to make forum topic.
Kajtek1 is online now
    HELP! S-320 will not start! but finally got to start with direct power to starter Newinport W140 S-Class 12 07-23-2013 12:49 PM
    87 560sl new starter, car won't start, it whines when trying to start jfs87560sl R/C107 SL/SLC Class 22 12-23-2011 09:28 PM
    82 MB 300SD will turn over but won't start, even with starting fluid.... s.odaugherty W126 S,SE,SEC,SEL,SD,SDL Class 2 08-24-2010 05:11 AM
    1982 MB 300sd will turn over but won't start, even with starting fluid... s.odaugherty W123 E,CE,D,CD,TD,TE Class 0 08-23-2010 08:26 PM
    Starter fluid.... Apathy W201 190-Class 0 12-11-2005 04:02 PM
