driver side glass replacement W124 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-07-2011, 10:06 PM Thread Starter
Date registered: Oct 2006
Hello, can someone please tell me how do you stick in the new driver side glass in the older W124 (mine is 1987 260E). A while ago, the driver side glass was broken (vandals). Anyway, finally got around to fixing it, I removed the door trim and stuffs, so I rolled the thing down and removed the slider pieces where the old glass was glued to. Now I looked at it and can't figure out how you are going to stick the replacement glass into the door. The replacement glass was picked up at the local junk yard and it looks like its glued solidly to the rubber boots and sits tightly inside the slider aluminium piece. Are you suppose to separate the two somehow? TIA
throne7 is offline
post #2 of 2 (permalink) Old 03-08-2011, 08:44 AM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Try asking in your cars specific forum.
W124 E,CE,D,TD Class - - Mercedes-Benz Discussion Forum
I believe you have to seperate the two, take off all rubber seals around the window, and slide the window in from the top. Don't quote me on it though..
1984babybenz is offline
    Driver Side Glass Replacement - Help RAN W163 M-Class 8 02-26-2011 03:04 PM
    driver side fog light glass cracked rleeclk55 C209/A209 CLK-Class 2 05-17-2007 03:42 PM
    Driver side mirror glass for 2001 S430 etrolley W220 S-Class 1 11-29-2006 11:41 AM
    Driver side Mirror Glass R&R ??? MBZ300CD W123 E,CE,D,CD,TD,TE Class 13 09-08-2006 08:35 AM
    driver side mirror glass drbranko R170 SLK-Class 9 05-12-2006 10:58 AM
