changing differential oil on my 1981 300D - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-06-2011, 09:49 PM Thread Starter
sierra1194's Avatar
Date registered: Mar 2004
Vehicle: 1981 300D, 1967 VW BUG
Had the front lower control arms, idler kit and a rear flex disc recently replaced at my Mercedes mechanic. And, oh yeah, front brake pads too. So now next thing is to get the alignment done.
My daughters boyfriend works for BMW is going to put my little Benz up on his rack over the weekend to: rotate my tires, change the differential oil, brake fluid, and align the wheels.
Should we use any particular weight on that differential oil: 75w90, 85w90? I'm in Los Angeles, CA if that makes any difference. And should brake fluid be Dot 4?
sierra1194 is offline
post #2 of 3 (permalink) Old 03-06-2011, 10:21 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
I believe it is 85w-90. You are better off checking the w123 forum though.
W123 E,CE,D,CD,TD,TE Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
post #3 of 3 (permalink) Old 03-29-2011, 09:42 AM
Date registered: Mar 2011
85W90
Break Fluid is dot 3 or 4
geoffscott is offline
1981 300D Oil return tube sethwm2 W123 E,CE,D,CD,TD,TE Class 6 01-23-2011 11:38 PM
1985 300D Turbo cracked vacuum line while changing oil, starter will not engage nate420 General Mercedes-Benz 1 08-02-2009 09:56 AM
changing differential fluid daryn R/C107 SL/SLC Class 28 02-07-2008 01:04 PM
Question about Changing the Differential s350thebest W124 E,CE,D,TD Class 4 02-04-2008 11:15 PM
Best Oil for a 1981 300D mamiller W123 E,CE,D,CD,TD,TE Class 4 04-27-2005 10:23 PM
