SLK 230 Trans fluid level - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-06-2011, 06:54 AM Thread Starter
Date registered: Mar 2011
Vehicle: 2002 SLK 230
I plan on changing my trans filter and gasket. How do you check the fluid level without a dipstick? Also what do you adjust for firmer shifts?
tjw307 is offline
post #2 of 2 (permalink) Old 03-06-2011, 09:03 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Better question for the SLK area of the roadster section. But if your car is like mine, you need a dipstick "tool" because there is not one in the tube. If you have a way to accurately measure the fluid you lose you could replace exactly that amount but using the tool is a better method. If you have a driver adaptive transmission, there are steps to re-set it to the factory settings and those should be firmer.
Musikmann is offline
    Trans Fluid level plink49 W124 E,CE,D,TD Class 7 02-24-2010 06:26 AM
    280SL Auto Trans Fluid Level? Anovak R/C107 SL/SLC Class 3 12-13-2009 05:01 PM
    Does anyone know the cost to change trans fluid on '98 SLK 230 Auto by UK Main Agent? miurasv R170 SLK-Class 7 01-26-2009 05:39 PM
    Trans fluid level, leaks my90300E W124 E,CE,D,TD Class 3 10-16-2006 02:20 AM
    SLK 230 How to check the transmission fluid level? silla R170 SLK-Class 0 09-10-2002 03:14 PM
