M271 engine problems, Timing chain skipped - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-04-2011, 04:16 AM Thread Starter
Date registered: Jan 2011
Question M271 engine problems, Timing chain skipped
My mate's W203 with M271 engine failed at 132000km. Mechanic found cam sprockets worn out and timing chain skipped. No vales were bent (leakdown test ok) but will be a costly repair according to mechanic. It needs both cam advancers, timing chain and tensioner replacement. Is this a known fault? Any idea about cost to get this fixed? (in Melbourne Australia)
loveamg is offline
post #2 of 2 (permalink) Old 03-31-2011, 04:33 PM
Date registered: Oct 2009
Vehicle: 2003 C230K M271 Engine
This has to happen on almost all M271 engines in my mind due to the smallest timing chain ever made being put on these cars. It is not good when the guy at the engine center you buy the parts from calls it a bicycle chain... so yeah its a known problem. My timing chain stretched enough on my 2003 c230 kompressor at 140,000 km to make the car barely run. Anywyas the dealership said that the chain was worn and also the timing sprockets were worn. The dealership said each sprocket was $900 dollars..so needless to say car was brought home to my dads garage and we took it apart. The chain was definately worn out but the gears looked fine, so we just put a new chain and new tensioner and 2 new guides on. It has been fine for 15,000 km now..but who knows how long this POS will last..i'm going to run it till it blows anyways.
Mercedes also had the brilliant idea of wedging the timing cover between the cylinder head and the oil pan. So once you take the timing cover off its impossible to get back on without either taking off the oil pan or the cylinder head. We decided to just cut the cylinder head gasket (3 thin metal gaskets) off the end overhanging the timing cover and wedge the timing cover back on with lots of gasket maker. The car did leak some oil out the front of the timing cover but more gasket maker on the outside edge has fixed that for the most part.
This job can be done yourself if you know what you are doing as everything has to come off the front of the engine to take off the timing cover.
I hope this helps.
travislunn is offline
    Engine Noise Timing Chain mike430sport W210 E-Class 29 05-10-2011 07:47 PM
    NEW FS: Radiator fluid, 190e- fuel filter/timing chain/timing chain tensioner ect Benznoob26 For Sale/Wanted/Trade/Giveaway 4 08-29-2010 11:31 PM
    timing chain problems/no start muchgold6 W202 C-Class 4 05-14-2010 04:58 AM
    Timing Chain, Intake Problems ccmginc General Mercedes-Benz 1 02-08-2010 02:44 PM
    timing chain conversion or new engine? rookierokus R/C107 SL/SLC Class 6 03-01-2009 08:26 PM
