coolant*leak* - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-02-2011, 02:24 PM Thread Starter
jballem's Avatar
Date registered: Mar 2011
Vehicle: 1978 450 SLC, 1993 S600, 1995 300E 4matic, 1992 190E 2.3, 1987 190E 2.3-16, 2010 Landrover Discovery
Post coolant leak
Hello i am new here but anyway, i have a 1992 190e 2.3 and there is a pool of coolant on my skid plate (which you have to remove to gain access to the oil pan) i know my Head gasket is not blown and the car runs beautifully but i cant see Where it seems to be coming from i can see the small puddle of it through the exhaust pipes coming off the engine (left side) i am not Sure what it could be i would think it is one Of the hoses if there Is any under there But i would appreciate any one's help as i am in distress. Also the fluid Is green i would think that it is coolant.
Thanks,
James
jballem is offline
post #2 of 7 (permalink) Old 03-02-2011, 04:54 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome aboard. Please click user cp and add your vehicle and location to your profile, it's useful information going forward.
The new member area is really just a place to introduce yourself and say Hi. The specific car forums is where tech information is freely available. Cruise down the main page to the W201 forum in the sedan section and post in there.
That said, no one here can tell you for sure where your leak is coming from based on what you've said. If you're not qualified to pull the covers and track it down, take it in and have it diagnosed, it could be lots of different things, from a hose to a water pump or anything in between...but guesses won't help you much. You are correct, though, that color is coolant and you definitely want to get it fixed. Check the level (cold engine) to make sure you're not running it low.
Good luck.
Check Codes is offline
post #3 of 7 (permalink) Old 03-02-2011, 05:16 PM Thread Starter
jballem's Avatar
Would you know if there are any coolant related hoses running down under or near the bottom of the engine? i would only hope it is a clamp or hose that is loose, I am qualified to pull the covers and take a look but it has been cold lately i will try and do it as the days get warmer thank you for you're quick response and welcoming me here.
Thanks,
James
jballem is offline
post #4 of 7 (permalink) Old 03-02-2011, 05:21 PM
Quoted: 35 Post(s)
None I know of. You have radiator hoses up front and heater hoses at the firewall, plus a few other places. But looking at a puddle is not how you find a leak. The leak could be quite a ways away, dripping onto something and then running to the low point before falling to the pan. As I say, you need to pull the pans and get in, under and around it and find the source. Puddles don't help much.
post #5 of 7 (permalink) Old 03-02-2011, 05:29 PM Thread Starter
jballem's Avatar
Okay well again thank you for repyling so quickly. i will pull the plate off and take a look in there and try to see what is going on.
Thanks,
James
jballem is offline
post #6 of 7 (permalink) Old 03-02-2011, 05:40 PM
eric242340's Avatar
Quoted: 312 Post(s)
Welcome to Benzworld
ERIC.
eric242340 is offline
post #7 of 7 (permalink) Old 03-03-2011, 02:03 PM Thread Starter
jballem's Avatar
I believe i have fixed my problem the hose to where the coolant leads to, the cap was loose and was leaking coolant so i took it off cleaned it because there were debris on the cap checked the coolant for any debris put it back on tightly started it up let it run for about 5 min and checked it, there was no leaks at all. Thank you guys for you're quick responses and suggestions. ,James
jballem is offline
Coolant leak MB-W202 W202 C-Class 14 06-04-2014 02:10 PM
Small coolant leak- addative to help trace leak? HACK THT W163 M-Class 10 02-08-2011 03:22 PM
Coolant leak 300E W140 S-Class 1 10-22-2010 11:59 AM
Coolant Leak jfunk W124 E,CE,D,TD Class 0 08-24-2005 01:13 AM
What does a coolant leak smell like with MB coolant? pcmaher W140 S-Class 3 09-27-2004 11:47 AM
