Help New Member - Car Written off by Key - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 03-04-2011, 08:20 AM Thread Starter
Date registered: Mar 2011
I expect MB to be accountable for limiting this consumable item.
dthornton is offline
post #22 of 25 (permalink) Old 03-04-2011, 08:25 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Originally Posted by keyhole View Post
In that case the technical limit will be 8 - although I can see no reason why an earlier code could not be reused...
I am not much a programmer, but I would assume that such procedure would take one of the CIA computers?
When a key on one of my MB stop working, the service adviser said "it died".
How passive electronic chip in dry key can just die?
Kajtek1 is offline
post #23 of 25 (permalink) Old 03-04-2011, 08:53 AM Thread Starter
Update
Mercedes never called me back yesterday so I called them this morning.
They had lost my notes? They did transfer me to Justin the Regional Manager and he advised that Mercedes would not assist in any way.
Yes most of you were correct.
post #24 of 25 (permalink) Old 03-04-2011, 09:17 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
This is clearly something to do with the digital coding of the key to communicate with the EIS. It seems to me that MB only allocated 3 bits to identify an individual key.
I thought when ordering a key at the dealer, the customer gets 2 choices, new key or replacement key.
For "new", the dealer will erase all "key#" in memory, start from key#1. Any key(s) that the customer have will no longer work.
For "replacement", the key number goes up by 1. Other old key(s) still work.
Apparently, 8 is the limit but "new" order should work in this "Car Written off by Key" case.
mbvis is offline
post #25 of 25 (permalink) Old 03-04-2011, 09:52 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 116 Post(s)
It is not passive. Each time you insert and turn key rolling code gets overwritten. On ML's typical failure scenario is attempt to start with dead battery. You turn key to start, starter goes click, there is not enough electricity to finish writing process. Key is history.
EEPROM in the key has limited number of write cycles.
EEPROM - Wikipedia, the free encyclopedia
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
    Help New Member - Car Written off by Key dthornton General Mercedes-Benz 4 03-02-2011 05:17 PM
    96 E320 key won't turn/car does not chime when key inserted bjzman100 W210 E-Class 11 12-19-2010 07:07 AM
    Valet Key starts Car, but Main Key does not. beamster R170 SLK-Class 13 12-08-2010 05:21 PM
    New Member-starting car help- resetting key Stephen1991 W210 E-Class 10 09-21-2010 07:10 PM
    Smart key hell - DVLA & NSL car Pound trying to steel my car ncoredump@gmail.com W210 E-Class 20 12-05-2009 10:17 AM
