new member needs help with 05 ML350 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-01-2011, 03:49 PM Thread Starter
Date registered: Mar 2011
Vehicle: mercedes ml350 2005
Unhappy new member needs help with 05 ML350
Recently purchased a 05 ml350 and have encountered the following problems with it at 49,000 miles.
needs a new a/c compressor pulley $465
replace the Rear Main Seal $1617
Transfer Case Output Shaft Seal $208
Front Brake Pads @ 2mm thickness $232
Brake Fluid Flush $99
Hood Struts $164
replace Transmission Cooler Lines $451
If I fix all of this should I be good for a while or is this just going to be a constant headache or repair this or that. this is my first MB and it is turning into a nightmare.
ml350-05 is offline
post #2 of 2 (permalink) Old 03-01-2011, 04:10 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Do a search of the w163 forum and see if there are any common failures with that model.
W163 M-Class - - Mercedes-Benz Discussion Forum
1984babybenz is offline
    new member needs help with 05 ML350 ml350-05 General Mercedes-Benz 1 03-01-2011 05:11 PM
    What are the Differences between 2007 ML350 and 2010 ML350? begone W164 M-Class 9 05-27-2010 04:46 AM
    will nerf bars on a 2000 ml350 fit a 2004 ml350? busoptr W163 M-Class 0 01-02-2009 09:55 PM
    Decision Help: 2006 ML350 vs 2007 ML350 MYML500 W164 M-Class 5 07-15-2007 02:59 PM
    Trading in the '03 ML350 for a new '06 ML350 AndyFracica W164 M-Class 0 12-22-2005 09:10 PM
