New member looking for help - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-28-2011, 08:27 PM Thread Starter
Date registered: Feb 2011
Angry New member looking for help
ok i have an 85 mercedes 200t with 4speed manual transmission and 4cyl gaz engine.
just put a new clutch and now the transmission is bad it's doing a noise that goes off when i push on the clutch pedal .
where can i get parts to rebuild this thing or a used one or if someone knows what else will fit in it? may be the 240d with 4spd manual.
the car is in really good condition and i need to fix it
may also need a starter and a front wheel bearing .
ghazigo123 is offline
post #2 of 3 (permalink) Old 02-28-2011, 09:59 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
eric242340 is offline
post #3 of 3 (permalink) Old 03-01-2011, 02:24 PM
Date registered: Mar 2011
Vehicle: 1974 450sl V8
New member Ray. I have a 1974 450sl that I have owned for 9months. Everything was
running fine until my radiator hose broke. I replaced the hose and then the car was
running rough and then would not start. Points were burnt so replaced points and rotor.
Point were set at 16 would run fine but after turning off ignition for 30 min. car will start
and idle rough. Cleaned plugs and checked coil. Any help would be appreciated. Thank you.
glasspack is offline
    New member vjjdavid General Mercedes-Benz 2 01-13-2010 07:43 AM
    Hottest SLK from a member or X-member of this forum... post them up. OJwerks R170 SLK-Class 21 01-28-2009 10:13 PM
    New Member Belstar General Mercedes-Benz 0 12-17-2008 10:47 AM
    wtf, i'm a "member" here but i'm a "senior member" at MBWorld!! asianml Off-Topic 8 11-23-2005 05:19 PM
