92 500sel - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-27-2011, 08:07 AM Thread Starter
Date registered: Feb 2011
Vehicle: 1992 500sel
92 500sel
I replaced the alt,battery,tensioner&belt. Still have no charge to the battery.
pfisher is offline
post #2 of 4 (permalink) Old 02-27-2011, 12:36 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Sure it's not just a bad battery?
Also, asking in the w140 forum will get more answers.
W140 S-Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
post #3 of 4 (permalink) Old 02-27-2011, 12:52 PM Thread Starter
alternator trouble
Thank you for responding. Can't get answer from other forum.
pfisher is offline
post #4 of 4 (permalink) Old 02-28-2011, 09:14 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
If you have done all that, have you actually put a volt meter on the battery? This might not apply but here you go. I never had a charging issue on my 92 SEL, I had my cluster rebuilt and the charge light would come on and then go away after a while, I had MB come out and checked the battery before replacing, the tech said it was fine, I replaced it anyway. A couple of weeks later same issue, I took it in new alternator, few days later light comes on intermittantly. They replaced the tensioner and belt, some weeks later same thing. The only reasoning I have is when they repaired the cluster the fault was introduced. The only common thing is that when the temperature is cold, the light comes on for a while, on warm days no issue. I have searched for loose connections, bad grounds, I can get the light to go out, when I turn on the seat heaters, and then back off. I did learn that the light will come on with under voltage or over voltage, which leads me back to the cluster.
Peter Guenther is offline
    m117.963(500sel before 1985) and m117.965(500sel after 1985) difference presscot W126 S,SE,SEC,SEL,SD,SDL Class 0 07-12-2010 07:14 AM
    500SEL 84 Grumbleweed W126 S,SE,SEC,SEL,SD,SDL Class 12 12-09-2008 04:29 AM
    89 500sel trans fit a 1991 500sel?? coully W140 S-Class 7 08-07-2007 01:33 AM
    help on my 500sel hcllc W140 S-Class 3 02-03-2006 11:07 AM
    Anyone need parts for a 500sel, I have 1984 500sel parting out nckmsn For Sale/Wanted/Trade/Giveaway 0 04-19-2005 02:06 PM
