190e B2 thrust pins fell into the oil pan - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-26-2011, 10:56 AM Thread Starter
Date registered: Apr 2008
Vehicle: 1992 Mercedes-Benz 190E 2.6L 4-speed
Hi everyone!
a few days ago, I was on my way to class and the transmision in my 190e lost all forward gears.
reverse works, so I thought that it might be the b2 piston based on what some others were saying on this forum. Well, I took the pan off and found that the trany fluid was clean. I then took of the filter and a short pin, what I now believe to be a thrust pin, fell out. I took the B2 piston out and realized that it was not that trust pin.
after digging around online I found a schematic of the transmission and found what looks like a second thrust pin on the opposite side of the brake from the piston.
my question is: what is the probable cause for this pin to have fallen out, and how do I fix it. here is a picture of the two pins. the shorter one is the one that I found on the filter.
I do not want to have to remove the transmission from the car if i don't have to.
Any help would be appreciated.
walleye0406 is offline
post #2 of 10 (permalink) Old 02-26-2011, 01:58 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 373 Post(s)
I'll say right now that I have no experience with this gearbox, but....
if you found those parts in the bottom of the pan, surely the most likely place they dropped from is the shift valve body, located immediately above.
The shift valve body, and the damper housing come off together.
keyhole is online now
post #3 of 10 (permalink) Old 02-26-2011, 03:43 PM Thread Starter
The title is a little misleading i guess. the pin actually fell off of the top of the filter when i took it off, as if it had been caught there before it could fall into the pan.
I'm a little concerned about taking the valve body and damper off. I'm no trany tech, and this is going a little outside of what I've ever done before, so any advice on what to expect would be awesome. also, is it ok to do that with the trany still in the car?
post #4 of 10 (permalink) Old 02-26-2011, 06:25 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Take a look here:
http://www.benzworld.org/forums/w201...3-722-4-a.html
I think it has a few links to different transmission threads that could help too.
1984babybenz is offline
post #5 of 10 (permalink) Old 02-27-2011, 02:16 PM Thread Starter
I got the pin in where it goes using hemostats, duct tape, two screwdrivers, a blunt punch, a mallet and four hands. working upside down. ill put some pictures up of the pin in location. there is some damage from where it came out in the first place, but im not sure that it is bad enough to fool with. question is how did it come out in the first place? the b-2 piston looks fine, though i'm going to go ahead and replace it along with the k1 springs, and maybe a modulator.
post #6 of 10 (permalink) Old 02-27-2011, 02:52 PM Thread Starter
these are the pics of my model/serial no. And the reinstalled thrust pin. (the smaller one of the pins i showed above.
I'd like to buy a new b2 piston. does anyone know which one i need?
there is 130K miles on the car. the original thrust pin is 42mm in total length which is contrary to what i have seen elsewhere(47mm). also what seals are included in the kit?
Im also going to need the K1 spring kit. i believe the part number is 126 270 44 77. is that right.
need a new rubber exhaust hanger.
post #7 of 10 (permalink) Old 02-28-2011, 10:15 AM
post #8 of 10 (permalink) Old 03-01-2011, 09:42 AM Thread Starter
Thanks a ton for the information. Hopefully I can get this thing back on the road soon.
post #9 of 10 (permalink) Old 12-10-2015, 06:43 PM
Date registered: Dec 2015
Vehicle: 1987 190DT
Hi there, did you get your problem resolved?
I have a 1990 190e and going through the precise same issue (found the small thrust pin on the top of the filter), just trying to figure my way around all this.
Thx.
Gerry McCrudden is offline
post #10 of 10 (permalink) Old 12-11-2015, 02:52 AM
Date registered: Jul 2005
Quoted: 971 Post(s)
He has not logged into the site since spring of 2011.
Noodles is offline
    oil pan removal on 1989 190E 2.6 HELP loletagm W201 190-Class 3 01-06-2012 10:32 PM
    190E oil pan removal and installation--help! loletagm General Mercedes-Benz 7 01-20-2010 07:57 PM
    Searching for 190E oil pan!!! Benzkid89 For Sale/Wanted/Trade/Giveaway 2 07-15-2009 05:40 PM
    crossfire oil pan = e320 oil pan? (upper pan removal?) fastmayte W210 E-Class 4 06-28-2008 05:06 PM
    WTB: 190E oil pan 190benz For Sale/Wanted/Trade/Giveaway 3 10-05-2005 04:57 PM
