38 pin to OBD2 adapter cable - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-25-2011, 08:08 PM Thread Starter
Date registered: Nov 2009
Vehicle: Mercedes Benz E300D w210 1999. 2005 scion xb
I forget to ask if anyone have tried to use a 38 pin to OBD2 adapter cable with a OBD 2 scanner to erase the SRS code on a 1999 W210?
I want to know if this will do the trick and save to buy a carsoft 7.4
I do have access to a obd @ scanner.
Thanks
Pedrodiesel
pedrodiesel is offline
post #2 of 5 (permalink) Old 02-26-2011, 12:37 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Thanks
Pedrodiesel
I doubt it would do anything for SRS. And are you expecting clearing codes to fix you issues anyway. Find a friend with Star and diagnose the issue (I would do it for free) and fix it, you save both the carsoft tool and the adapter.
Diesel Benz is offline
post #3 of 5 (permalink) Old 02-26-2011, 12:51 AM
eric242340's Avatar
Quoted: 296 Post(s)
^+1 Also the 38 pin connection cars worked with HHT software which is also incorporated into SDS so I doubt if any scanner other than SDS will do it.
That said there are some scanners around that can do 38 pin, I believe American special tools did one.
ERIC.
eric242340 is offline
post #4 of 5 (permalink) Old 02-26-2011, 05:19 AM Thread Starter
Thnaks for the reply
Thanks for the reply and the offer to do it for free. ( I think we are a little to far away.....), I do know anyone in the area that have the star
the SRS light came On when working on the steering column (Tighten a bolt) they is not issue to fix with the car. Is just the light is on.
Considering in buying a scanner, ( probably carsoft 7.4)
Not sure, (seems a bit complicated)...
Thnaks
pedrodiesel
post #5 of 5 (permalink) Old 02-26-2011, 05:21 AM Thread Starter
38 pin scanner
Thanks Eric for your help I keep looking for a scanner suitable for MB.
Pedrodiesel
    13 pin Connector Adapter jorex W210 E-Class 12 02-13-2010 10:03 PM
    38 pin to 16 pin OBD II adapter vfhondas R170 SLK-Class 3 02-09-2010 11:28 PM
    38 Pin 'break-out adapter'?? Behind Blue Eyes R170 SLK-Class 2 03-25-2009 07:39 PM
    The Retriever adapters (M 4041 38 pin adapter) Cixi R170 SLK-Class 4 07-07-2008 09:36 PM
    test box and 25 pin cable ramses For Sale/Wanted/Trade/Giveaway 0 10-31-2005 07:16 AM
