2004 ML Visor Clip Stuck - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-22-2011, 03:40 PM Thread Starter
Date registered: Feb 2011
I need to replace my drive side visor clip. I bought the new one and it seems really simple. But the old one is stuck.
I flipped over the little cover with a flathead screwdriver. I then used the screwdriver to unclip the only clip that I see. I pulled very hard with my fingers. The old clip wiggles about 1mm side-to-side but does not come loose. Do I just need to pull harder with pliers?
I just want to be sure I do not cause expensive damage to where the clip is connected.
cal123 is offline
post #2 of 2 (permalink) Old 02-23-2011, 12:13 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
The WIS instruction for removing the sun visors advise the use of an upholstery 'wedge' to pry the item out from the roof panel. This is a slim, plastic wedge-shaped device also used to remove the covers from doors, etc.
If you don't mind damaging/breaking the old clip, a firm tug with your pliers should do the trick....
keyhole is offline
    Sun visor clip replacement Digmenow R/C107 SL/SLC Class 38 07-23-2015 05:52 PM
    sun visor clip replacement rctraveler Vintage Mercedes-Benz 0 04-06-2010 05:27 PM
    Sun visor clip baphomet1003 W163 M-Class 1 11-09-2009 09:41 AM
    sun visor clip z168 W201 190-Class 9 05-03-2007 06:27 AM
    Rear visor clip Robschaef W124 E,CE,D,TD Class 0 04-24-2005 08:01 AM
