ML270 cdi - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-20-2011, 03:45 AM Thread Starter
Date registered: Feb 2011
Vehicle: 2001 ML270 cdi
ML270 cdi
hi guys!
i recently bought a 2001 ML270 cdi, sad to say, i cannot really comment on its performance, because the moment it left the dealer, a few problems started sprouting and hopefully you guys can help out. The car is in service for almost a week now and still can't figure out what's wrong.
First, while i was accelerating from stop, there was a sudden pop. Turned out the turbo piping which is connected to the engine popped out with all the clips intact though, so i just had the piping cleaned and returned.
Second, i suddenly lost my brakes, brake pedal going to the floor. So i had my brake master changed. But a new problem was discovered, brake fluid is not reaching my rear left wheel, had it bled already but no use.
They believe the abs pump is the culprit because upon close inspection of the module, fluid leaves the three little pipes coming from the abs pump except for one. Is there anyway to just repair the abs pump rather than replacing it entirely? It's quite pricey.
Hope you guys can help out. I really want to use my car already. Thanks!
gjo507 is offline
post #2 of 2 (permalink) Old 02-20-2011, 05:26 PM
eric242340's Avatar
Quoted: 296 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is offline
    looking for info on ml270 cdi davo W163 M-Class 5 02-03-2011 02:52 PM
    ML270 cdi brabus d4 lmy450 W163 M-Class 0 07-24-2007 07:07 AM
    ML270 CDI availability dmviejo W163 M-Class 1 02-19-2005 05:57 PM
    ML270 CDI Bob77 General Mercedes-Benz 0 01-31-2004 09:28 AM
    ML270 CDI OR ML350 AnE2pleaz W163 M-Class 10 07-29-2003 10:44 AM
