Wont start after oil change - Timing Chain? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-19-2011, 11:05 PM Thread Starter
Date registered: Mar 2006
Vehicle: Mercedes 420 SEL 87'
Car wont start after oil change. Has spark & fuel, i believe the timing chain has jumped a tooth or two. Two cylinders are 0 compression, does this mean there could be valve damage aswell or can it all relate to the timing? Is it an expensive fix to have the timing chain adjusted?
Louie_D is offline
post #2 of 2 (permalink) Old 02-20-2011, 07:40 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 176 Post(s)
Timing chain
is tensioned by an idler sprocket positioned by a hydraulic piston. That hydraulic assembly is supposed to fill with engine oil and retain pressure for a long period of time, theoretically forever but in practice several weeks anyway.
One of the failure modes is an inability to rertain pressure thus allowing slack in the chain until pressure is restored. Worst case for you is that your conjecture is correct and the chain has skipped links because of the slack and your valves have collided with your pistons..
Lack of compression in some cylinders is not a good sign. And to answer your last question, yes, the worst case situation is very expensive to repair. Basically a rebuild of the top end of the engine.
I would suggest you cease attempts to start the engine until you assess potential damage. Pull your valve cover off and have a look. You could get lucky.
rocky raccoon is offline
    Car ran great but slowed,Stopped and now wont start.Timing Chain??? mxcrasher R/C107 SL/SLC Class 12 05-14-2008 11:13 AM
    HELP!...Timing chain adjustment and engine wont turn! miroxz W140 S-Class 16 02-26-2008 12:06 AM
    oil/filter change and now wont start noShame W202 C-Class 0 09-26-2007 09:34 AM
    oil change and timing chain lancer W123 E,CE,D,CD,TD,TE Class 20 06-01-2006 08:27 AM
    Changed chain tensioner, now the car wont start, help! Chain alignment not correct!? johan6504 W124 E,CE,D,TD Class 0 10-25-2003 06:25 AM
