94 E-320 idle problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-18-2011, 03:27 PM Thread Starter
Date registered: Feb 2011
Vehicle: 1994 E-320 Sedan
Hi. I have a 1994 E-320 which recently started having an idle issue when at operating temp.
Quick time line: My Ce light came on about 4 weeks ago. Was told it was the upstream O2 sensor. Didn't repair immediatley. About 2 weeks into the CE light being on my engine started to have the idle problems. The idle is fine during the first 5-10 minutes of operation.
At an idle the rpms will increase to just above 1K then quickly drop below 500. This will repeat several times and if I don't start moving again the engine will eventually die.
I just replaced the O2 sensor and still having the same problem.
Any ideas would be appreciated
Thanks
jsfosdick is offline
post #2 of 2 (permalink) Old 02-18-2011, 05:44 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Search in this forum, might have the same issue
W124 E,CE,D,TD Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
    Testing Idle Valve - High Idle Problem Jonathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 16 08-11-2012 05:55 AM
    98 E-320 Idle speed luisv-rod W210 E-Class 1 10-31-2010 10:38 AM
    Idle Problem-surging Idle-1990 560 SEC gregory113513 W126 S,SE,SEC,SEL,SD,SDL Class 3 08-14-2009 10:42 PM
    ML 320 Engine Idle, please help stevhuff W163 M-Class 9 07-08-2009 07:36 AM
    what degree does your 320 idle at? lowrinlife C208/A208 CLK-Class 4 03-28-2007 06:10 AM
