Clay bar?? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-17-2011, 12:22 PM Thread Starter
Date registered: Jan 2011
Clay bar??
I have seen a few posts at this site about using clay bars to restore the finish on vehicles. I have never had any experience with using these and any information on clay bars would be appreciated.
I'm guessing they might remove or fill in remove surface scratches on the paint or brighten up the sheen of the paint. Also what method would I use to get the best results from it.
Ezio Iacobucci
08 ML 320 CDI
yakker1957 is offline
post #2 of 5 (permalink) Old 02-17-2011, 02:44 PM
millpond's Avatar
Date registered: May 2010
Vehicle: 2007 SL 550, 50th Anniversary Edition
Ezio Iacobucci
08 ML 320 CDI
Clay bar will not remove or fill-in scratches. It will remove surface dirt that isn't removed by washing or waxing. You need to use a lube like soapy water when using the bar. Any auto supply store will have a clay bar kit that includes the lube and instructions.
millpond is offline
post #3 of 5 (permalink) Old 02-17-2011, 02:54 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Did you know there is a DETAILING tech forum on this site that will teach you all you need to know about all of this, and more? Just scroll down the main page until you see it.
Check Codes is offline
post #4 of 5 (permalink) Old 02-17-2011, 02:55 PM
Mark Essman's Avatar
Date registered: Dec 2008
Vehicle: 2005 230 Kompressor
This might help
How To Detail Clay Your Car - Auto Detailing Clay and Clay Alternative
2005 230 Kompressor SS
Mark Essman is offline
post #5 of 5 (permalink) Old 02-17-2011, 03:26 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
It will not fill in or remove acratches, but will remove contaminants from the paint.
As stated above, the detailing section has info on this.
1984babybenz is offline
    Doesn't anyone have a clay bar? Gregs300CD Off-Topic 7 07-19-2007 04:39 PM
    clay bar yoseyman C208/A208 CLK-Class 3 11-17-2005 10:49 PM
    Clay bar jtigr R170 SLK-Class 7 05-25-2004 04:07 PM
    best clay bar amgbnz Detailing and Car Care 11 04-29-2004 02:11 PM
    Clay bar? bgoin Detailing and Car Care 1 04-10-2003 03:41 PM
