1998 SLK230 A & B Maintenance Question - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-14-2011, 10:06 AM Thread Starter
Date registered: Aug 2010
Vehicle: SLK230 1998
Where can I find out what is included in the A & B Services ? I found one link but it was a dead end.
w1ksz is offline
post #2 of 6 (permalink) Old 02-14-2011, 10:37 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Surely those have been discussed in the proper section of the roadster forums. Try looking there and don't forget to check the stickys.
Musikmann is offline
post #3 of 6 (permalink) Old 02-14-2011, 10:46 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If you're going to DIY, they're useful.
Otherwise, if you are taking it in, then have the shop give it to you. Some include other things with it, and it's useful to know what those are.
On a side note, where is Vail, AZ? I'm from Phoenix originally and have been all over the state, but the only Vail I've been to was in the Rocky Mountains of Colorado.
Check Codes is offline
post #4 of 6 (permalink) Old 02-14-2011, 10:49 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
It's in the service manual that came as part of the owners manual packet. You can still get them from MBUSA. If you don't have an owners manual, you really need to have one of those too, also still available. You might get lucky and be able to get the entire packet on e-bay.
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - for sale - http://www.benzworld.org/forums/w123...g-my-240d.html
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
post #5 of 6 (permalink) Old 02-14-2011, 11:14 AM
millpond's Avatar
Date registered: May 2010
Vehicle: 2007 SL 550, 50th Anniversary Edition
From Mercedes of Portland Oregon:
The A Service includes the following:
Reset maintenance service indicator in instrument cluster
Engine oil and filter change with synthetic oil and factory Fleece oil filter
Hood: Inspect catch, safety catch, and hinges on engine hood for proper operation and
lubricate if necessary
Inspect condition of poly v-belt for cracks, breaks, or excessive play
Clean water deflector to ensure proper drainage
Inspect coolant level and test coolant for proper composition
Check thickness of brake pads and rotors; front and rear
Correct tire inflation pressure and measure tread depth
Inspect tires for any abnormal wear or damage
Correct inflation pressure in spare tire (if applicable)
Inspect power steering system fluid level and check for leaks
Inspect wiper blades condition
Verify proper operation of horn and all interior and exterior lighting functions
Adjust headlamp settings if necessary
Test condition of main battery & auxiliary battery (if applicable) using "Midtronics MCE 717" tester
Check and correct fluid level of battery (if applicable)
Check windshield washer and headlamp cleaning system
Activate tire pressure monitoring if needed
Visually check brake system components, lines, hoses, and calipers
What is a B Service?The B Service is the larger service. It includes everything in the A Service and the following:
Remove and inspect combination or dust filter and replace if needed
Check underbody for leakage from major components. Inspect for chafe marks, line routing,
damaged components.
Visual inspection condition of front axle, ball joints, and rubber boots
Visual inspection of driveshaft flexible discs
Visual inspect condition of mechanical steering components and rubber boots
Function test parking brake
Check seat belts and buckles for signs of external damage and proper function
Clean and lubricate tilt/sliding roof mechanism
Clean and lubricate panoramic roof mechanism
Check bodywork for paintwork damage
Check chassis and load-bearing body components for damage and corrosion
millpond is offline
post #6 of 6 (permalink) Old 02-14-2011, 11:25 AM Thread Starter
Thank you for your response, that's what I was looking for.
w1ksz is offline
    1998 C230 Maintenance & Repair Log SParkyMerc W202 C-Class 2 04-17-2013 04:37 AM
    SuperCharger Question SLK230 1998 KiwiSlk230 R170 SLK-Class 47 02-01-2009 01:10 PM
    maintenance tips for 1998 SL500 confusion R129 SL-Class 6 09-25-2008 10:23 PM
    most reliable & trouble-free 1998 Mercedes from 1998-2003? ProV1x General Mercedes-Benz 10 02-07-2007 09:53 AM
    New owner: What does the maintenance schedule look like for SLK230? Black98SLK230 R170 SLK-Class 4 12-10-2003 08:31 PM
