Never trust a thermostat - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-11-2011, 04:51 AM Thread Starter
Date registered: Feb 2011
Vehicle: 1994 sl320 r129 and a 1991 300e w124
Angry Never trust a thermostat
After fitting a new thermostat to my W124 1991 300E I experienced problems with overheating which at first I thought was airlocks in the system, after I changed the rad and replaced the viscous coupling and exp. tank cap the problems still existed, after a lot of head scratching I removed the `new` thermostat and tested at home, now it states that it should start to open at around 80c and be fully open at100c, not the case though even submersed in boiling water direct from the kettle there was still no movement, even after ten minutes, I took it back and got a replacement which again I tested at home only to find the same results. back to the store with it and the staff tested it also with the same results it is now on its way back to Brazil for further test by the company who make it M.E. Thomson of Brazil, Stick with German units as this could of caused serious damage to the engine, I suppose other will scratching their heads as well as a result of this faulty batch..
silver machine is offline
post #2 of 4 (permalink) Old 02-11-2011, 05:43 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 341 Post(s)
Good tip. We should always test a thermostat at home before installing it. It is simple enough to test.
keyhole is offline
post #3 of 4 (permalink) Old 02-11-2011, 06:14 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Mi experience with Brazilian parts is totally negative, be it Bosch plugs or no name thermostats. The difference between these parts and European or US made components is spent many fold in medicine for headaches.
Sorry about your experience, change supplier.
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
post #4 of 4 (permalink) Old 02-11-2011, 07:18 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Exactly the reason to stay OEM.
Lucky it didn't cause any permanent damage!
1984babybenz is offline
    Can't trust anyone edfreeman Off-Topic 11 10-05-2010 04:11 AM
    Who Do You Trust? Qubes Off-Topic 75 08-19-2010 06:35 AM
    Trust ThrillKill Off-Topic 9 03-12-2009 10:10 AM
    Never trust mlfun Off-Topic 6 01-13-2009 03:24 PM
    Who do you trust? TLC 320 R170 SLK-Class 6 02-11-2005 10:07 AM
