1985 MB 350 SL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-10-2011, 08:57 AM Thread Starter
Date registered: Feb 2011
Exclamation 1985 MB 350 SL
Hello, my name is Nathan and I have a 380 SL.
I'm unable to get it started: It will start and run for a few momnets but cuts off after I've i mash the gas pedal. I've realized, fuel is not traveling towards the front (fuel distributor).
The car has been sitting for several years with gas in it.
I've changed the fuel pump (after draining the tank) and replaced the fuel filter; and ordered a another fuel pump relay.
I don't know where to start with trouble shoooting the cause of fuel not gettig to the fuel distributor (it's dry).
There are so many options to troubleshoot:
1.Warm-up compressor
2. Control unit
3. Idle speed adjuster
4. Cold Start valve
5. Fuel reservoir (acculmulator)
I'm gonna drain the tack again and see if any particles are stuck in the screen' blcoking the flow of fuel.
nkelleyiii is offline
post #2 of 3 (permalink) Old 02-10-2011, 07:54 PM
eric242340's Avatar
Quoted: 296 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is online now
post #3 of 3 (permalink) Old 02-11-2011, 09:33 AM
slik560's Avatar
Date registered: Aug 2007
Vehicle: 1987 560SL / 2003 ML320 / 2006 Mini Cooper S
Quoted: 19 Post(s)
Welcome! As a fellow SL owner, I strongly urge you to head down to the R107 forum and start asking questions. LOTS of information and knowledge there.
Kevin
slik560 is offline
    1985 350 ????? cooljjay W123 E,CE,D,CD,TD,TE Class 12 12-31-2008 01:34 PM
    1985 300d vs 1985 300sd bhay4g General Mercedes-Benz 6 11-12-2008 09:00 PM
    1985 500se for $350.00 MW126 W126 S,SE,SEC,SEL,SD,SDL Class 3 02-10-2008 04:54 PM
    WTB: w209 navigation unit, taillights for clk 350, front bumper from clk500/350/amg ekohan For Sale/Wanted/Trade/Giveaway 0 12-22-2006 04:53 AM
    SLK 350 - £350 tuning = 4.2secs to 60???! bsharp R171 SLK-Class 7 11-08-2004 06:55 AM
