Check engine code - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-07-2011, 08:46 PM Thread Starter
Date registered: Feb 2011
Vehicle: 2004 SL600 with Veloce 600 hp ECU tune
Check engine code
How can I find the trouble code for a check engine light issue. on my
2004 SL600
Garylns is offline
post #2 of 9 (permalink) Old 02-07-2011, 10:20 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Scan for them, then search here or on the internet when you have the code(s). Or post them in your car's home forum (rather than this general one) and your compatriots will lend a hand.
Good luck.
Check Codes is offline
post #3 of 9 (permalink) Old 02-07-2011, 10:55 PM Thread Starter
scan for code
Thanks, got it
Garylns is offline
post #4 of 9 (permalink) Old 02-08-2011, 08:25 AM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Advance Auto has a free obd scanner you can use. It will give you the code, and as stated above, search the internet for what it means.
1984babybenz is offline
post #5 of 9 (permalink) Old 02-08-2011, 09:34 AM Thread Starter
code reader
Thank you very much, I decided to just buy a reader so I will have it in the future. I plan to keep this car for a while.
Garylns is offline
post #6 of 9 (permalink) Old 02-08-2011, 09:45 AM
Quoted: 35 Post(s)
Good decision. I have a small one (basically the $30 job from Amazon) that I simply leave in a pouch under the front seat so it's handy when the need arises.
If you haven't pulled the trigger yet and plan on buying only one (they can be used on other makes, too) then I'd encourage you to consider one of the true scanners that can capture real-time data as well as read and erase codes. That's useful for more involved diagnoses. Innova makes some affordable models.
post #7 of 9 (permalink) Old 02-08-2011, 09:58 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
If you got a laptop, get the CAN-BUS Auto Scanner, ELM327 USB CAN-BUS Auto Scanner, $30.
It plugs into OBD port, the USB cable to your laptop.
It does more than a handheld scanner such displaying voltages of O2 sensors.
# Features: ELM327 is the latest PC-based scan tool. It supports all OBD-II protocols and is dispatched with a number of compatible programs. The processor is an ELM327. The output protocol (connection to laptop) is USB.
# Processor: ELM327.
# OBD-II Software for ELM327 is a free program that allows you to use your PC and a hardware interface to get the information from your car's computer.
# The program is very user-friendly, and easy to learn. It is also very easy to install: simply extract the files into a folder on your computer's hard drive, and you're ready to go. To uninstall the program, simply delete the entire contents of the folder where the program resides.
# The software supports two platforms - DOS and Windows.
# The program lets you perform the following operations: Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
# Clear trouble codes and turn off the MIL ("Check Engine" light)
# Display current sensor data, including:
Engine RPM
Calculated Load Value
Coolant Temperature
Fuel System Status
Vehicle Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen sensor voltages / associated short term fuel trims
Fuel System status
Fuel Pressure
Many others...
mbvis is offline
post #8 of 9 (permalink) Old 02-08-2011, 10:57 AM Thread Starter
Thanks, I ordered an Equus scanner for $90.00. I like the laptop idea. if I'm not happy with the Equus I'll send it back and try your recomendation.
Garylns is offline
post #9 of 9 (permalink) Old 02-08-2011, 12:47 PM
I bought an Actron cp9185 on sale for $85 a few weeks back. It is really good and can basically do anything the dealers can.
Already had to use it a few times, on both mine and friends cars haha
check engine light code reader and code list JimAB W201 190-Class 3 05-08-2013 06:39 PM
Need help with a Check Engine code jorioux W202 C-Class 9 06-27-2010 04:52 PM
check engine code 12 banyan W126 S,SE,SEC,SEL,SD,SDL Class 0 08-23-2008 08:10 AM
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
check engine code empirical R129 SL-Class 0 03-30-2006 01:49 PM
