Is my transmission shot? - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 02-06-2011, 01:56 PM Thread Starter
Date registered: Feb 2011
Thanks for your reply, could you elaborate a bit more on that, I'm not sure if i understand what u r saying. when I select Any of R, D, 3 and 2 all engage and the car drives but does not shift from 2nd gear which is the starting gear.
bb201 is offline
post #12 of 13 (permalink) Old 02-06-2011, 02:39 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 341 Post(s)
Not too sure myself about MB wording there...
I guess it means that 2nd doesn't engage - which you say yours does. OK, how about this one?
Upshifts only in upper speed range.
1. Check control pressure cable, adjust if neccessary.
2. Remove solenoid valve and check needle valve for dirt and ease of movement.
3. Check governor pressure, clean or replace the centrifugal governor in the event of variations.
4. Check control pressure regulating valve for ease of movement.
btw, I'm just reading the WIS. I'm not a transmission expert!
keyhole is online now
post #13 of 13 (permalink) Old 02-06-2011, 02:46 PM Thread Starter
I'm going to do those checks. the weird thing is that it engages in all selector positions but as i start driving it doesn't upshift. that's why i still have hopes for a not so serious problem. I don't know how these trannys behave when they are kaputs so I can't compare to mine. i drove it for 10k to get to the shop always in 2nd (slowly) without incident.
bb201 is offline
    The First Shot? Qubes Off-Topic 5 09-25-2009 10:37 PM
    c280 transmission shot?? slowfncar W202 C-Class 16 11-15-2008 11:23 AM
    Transmission shot? Kalifornia W126 S,SE,SEC,SEL,SD,SDL Class 17 04-01-2006 07:40 PM
    Is My Transmission Shot?!?!?!? 89_260e W124 E,CE,D,TD Class 6 07-06-2005 03:05 PM
