2000 S430 Airmatic Question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-02-2011, 08:52 PM Thread Starter
Date registered: Feb 2011
Hello everyone. New to the Forum here. Forgive me for asking, as I'm sure this has been covered.
Traveling from California to Oklahoma the past few days. Stayed in Flagstaff Monday night and Amarillo, TX last night. Temperature dipped to below zero in Amarillo. When I walked out to the Benz at 7:30am the car was low and I get an Airmatic warning not to move car when I started the ignition. Immediately, the Airmatic activated and within 90 seconds the car was back up to normal. This is the first time this has happened to me, but I've never been in zero temps with the car before.
My S430 has 77,000 miles on it. Did the car lower because of the low temperature and is this normal? It didn't lower the night before in Flagstaff, but the temperature didn't fall below zero either.
Any forthcoming advice or suggestions are appreciated. Thank you in advance.
paxjea is offline
post #2 of 3 (permalink) Old 02-03-2011, 07:57 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
The car likely got low because of the low temperature making the air valves leak at the airmatic spring(s). On W/S211 models this is pretty normal (happens every now and then) but I would still say it is a valve failure, the valve should not leak at cold temperatures either.
As long as it is only the valve, there is not much to worry about. But if a corner always drops (like overnight), there must be a leak in the lines or the spring and something would have to be fixed soon.
Diesel Benz is offline
post #3 of 3 (permalink) Old 02-03-2011, 08:17 AM
mrelbe's Avatar
Date registered: Jul 2004
Vehicle: 91 300SL with Pano Top, 04 S500, 2015 Tesla Model S
Quoted: 76 Post(s)
Same problem here, front end bottoming at cold temperatures ( < -25C = < -13F ) with my 2004 S500. Looks like the Airmatic seals are failing at cold temperatures. What twisted MB engineering mind came up with elaborate sensors and dashboard warnings instead of just installing a simple hard rubber bumper to prevent complete bottoming?
91 300SL with Pano Top, 2014 Tesla Model S P85D Ludicrous
formerly 1980 450SL, 1990 560SEL, 2004 S500
Black Fuzzy Dice Gang Member
http://www.benzypalooza.com/
mrelbe is offline
    2000 S430 AirMatic Problem Adam00S430 W220 S-Class 10 09-16-2013 02:36 AM
    hi everyone, 2000 benz s430 -airmatic issue wolf532 General Mercedes-Benz 0 10-11-2010 05:37 AM
    AIRMATIC PROBLEM 2000 S430 charburt8 General Mercedes-Benz 3 07-11-2010 11:11 AM
    Airmatic/BAS on 2000 S430 Guest (MBNZ) W220 S-Class 12 05-14-2010 09:20 AM
    2000 S430 airmatic suspension mencio W220 S-Class 1 11-04-2008 11:53 AM
