S600 W220 2001 flaws - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-02-2011, 03:02 AM Thread Starter
Date registered: Feb 2011
Question S600 W220 2001 flaws
Hi
I am in the process of having the exhaust, gearbox and engine removed (by an MB dealer) to repair an ABC hose leak. I have already had the oil cooler repaired and as the whole lot is coming out, I wanted to ask if there is anything else I should get done whilst it can be got at.
Thanks in advance.
Timbertool is offline
post #2 of 4 (permalink) Old 02-02-2011, 10:23 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
With the engine removed, the dealer should tell you if the engine mounts, oil seals, or other things needing to be replaced.
mbvis is offline
post #3 of 4 (permalink) Old 02-02-2011, 10:45 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Ditto to oil seals or gaskets. From what I've read all the 12 cylinder engines develop oil leaks and typically after the warranty expires. Have them check your oil cooler too. Plus have a look at the W220 forum to see if they have a sticky for common issues.
Musikmann is offline
post #4 of 4 (permalink) Old 02-04-2011, 03:14 AM Thread Starter
Smile
Thanks for you input.
    Computing data? - W220 S600 02s600amg General Mercedes-Benz 0 09-21-2010 09:16 PM
    W140 S600 v. W220 S55 AMG/S600 W140FTW W140 S-Class 51 08-10-2010 07:57 PM
    2001 S600 w220.178 Oil coming out of the engine wiring harness at the control module box. k.bop W220 S-Class 17 06-02-2009 11:43 AM
    differences between W220 S600 euro? mboftampa W220 S-Class 5 08-29-2008 10:46 PM
    2001 S55 or 2001 S600? which one do u recommend? koreanpers W220 S-Class 0 09-03-2005 02:27 PM
