Oil leak/seep - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-01-2011, 01:32 PM Thread Starter
Date registered: Jun 2008
Oil leak/seep
Hi All,
I crawled under the car today to check the engine mounts and saw that there seems to be oil seeping or leaking out of the the exhaust headers(i think). It is just this one connection that has the problem.. the other ones seem fine. Do you guys think this is a big enough problem to warrant repair? (I have third party warranty, but the parts approval process can be a PITA if the problem is small).
bprocks is offline
post #2 of 3 (permalink) Old 02-02-2011, 12:15 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
I'd be about 99% certain this oil has dripped to this location from somewhere else.
If oil could escape at this exact site, so could exhaust gas and you could likely feel it and hear it happening.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 02-02-2011, 12:19 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Plus one to Kent's comment.
You posted into the general forum with no identification of the car. Please click user cp and add your vehicle and location to your profile, it's useful. Also, please note that there are specific forums based on your chassis. If you scroll down the main forum page you'll see them all, find yours and look in there or post. You may find someone that can tell you exactly because they've seen it before.
But yes, that's pretty wet for a leak, so I'd definitely check into getting it fixed.
Good luck.
Check Codes is offline
    Engine oil leak - front pulley oil leak? southbusiness W210 E-Class 4 04-25-2009 05:41 PM
    Head gasket oil leak...stop leak products? lisam W202 C-Class 8 04-11-2009 02:55 PM
    Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
    oil seep from filter housing 300TDChugChug W123 E,CE,D,CD,TD,TE Class 0 11-01-2005 01:53 PM
    My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 06:21 AM
