key wont fit in trunk lock - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-01-2011, 09:24 AM Thread Starter
Date registered: Jan 2011
Smile key wont fit in trunk lock
Hi
The key does not fit in the trunk look on my C180 from 1996 (sedan).
It fit in the hole, but it is like it needs to get in 1 more centimeters extra to be able to unlock and lock.
I have tried to blow with air compressor and sprayed oil, but it doesn´t work.
Have you any ideas on what I can do to fix it?
Best regards / Vilhelm
Here is a little illustration:
vilhelm is offline
post #2 of 2 (permalink) Old 02-01-2011, 03:36 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Might be that lock needs to be replaced. But I would try some other oils or lubricants before doing that. Try something like white lithium grease or powdered graphite. Plus there are products (Locktite I think is one of them).
Is it cold where you are now? It might be only frozen water in there and for that you can heat the key with a butane lighter and then insert it to melt the ice.
Musikmann is offline
    doors / boot wont lock - key wont turn alberto28 W202 C-Class 0 05-16-2010 12:33 PM
    boot wont,t lock on key remote. bcw15 W210 E-Class 1 11-26-2009 12:27 PM
    Key ignition wont lock or unlock. OneLoveE55 W210 E50 AMG, E55 AMG 5 12-05-2006 09:25 AM
    trunk wont lock... rib W124 E,CE,D,TD Class 1 04-30-2006 12:44 PM
    300SD Lock Problem: CANT LOCK TRUNK WITH KEY?? regsatx W126 S,SE,SEC,SEL,SD,SDL Class 1 11-27-2004 08:57 PM
