CLS 320CDI gives a lot of white smoke more than 5 minutes - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 02-09-2011, 05:24 PM Thread Starter
Date registered: Jan 2011
Dear isstay, if what u said is correct, how do i fixed it before it will be getting worst? ANd also as you point out read AP4720P0780T, where can i find and read it? Thank you
soffean193 is offline
post #12 of 17 (permalink) Old 02-10-2011, 03:43 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
Just to clarify here (and in mitigation for my mistake!)
Not ALL MB deisel engines have a fuel filter fitted with a water level sensor.
Drawing AP4720P0780T is in the WIS (MB workshop manual) and does show this feature for MB with Code 494 (USA version)
Drawing AP4720P0780 shows the fuel filter WITHOUT a water level sensor. (no electrical connector at the top of the filter)
So what type of filter do you have? with connector or without?
keyhole is online now
post #13 of 17 (permalink) Old 02-10-2011, 06:52 AM
Vehicle: 2015 Audi S4, 1982 Fiat Spyder, 2010 R350
The amount of white smoke the OP described would be more than just a little water in the fuel. I'd have to guess the head gasket or even a cracked head.
Take a look at the oil on the dipstick. If cloudy, milky or foamy, then water is in there also.
gforaker is offline
post #14 of 17 (permalink) Old 02-10-2011, 08:48 AM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Good point, the default at this forum would be the US and one could assume that from a member who does not indicate his/her location in the profile but then again, I think the car was a CLS CDI which cannot be a US car.
Diesel Benz is offline
post #15 of 17 (permalink) Old 02-10-2011, 09:52 AM
~BANNED~
Date registered: Mar 2009
Vehicle: 2006 E320 CDI
Quoted: 4 Post(s)
isstay - my sincere apologies to you Sir. You are absolutely correct, as DB has just pointed out.
Apologies accepted.
Here is some more info about it if you like, see attached files:
As is been pointed this is for US models, code 494, or U41 code, maybe for rest of the world, not sure. I saw that the car is in Bruney, but I don't know were U41 applies.
Water has lower weight than diesel, so it will stay on top of it. Soffean193 did you notice if your car smokes when you tank is full or almost empty? If it does when empty most likely will be water in the fuel. If it does when tank is full you probably have different problem. I also would keep eye on coolant level. I don’t know if you install one of those filters with water separators how will work for your car. Maybe will be fine but you will have to check it manually for water levels and empty it since it is not going to alarm you, maybe will create back pressure on the fuel pump inside the tank and trigger some error code.
isstay is offline
post #16 of 17 (permalink) Old 02-10-2011, 09:55 AM
~BANNED~
Quoted: 4 Post(s)
It is very rare for the head gasket to blow in both directions: to the oil and to the coolant passages. Although it may happened some time. He most likely does not have dip stick ,but will get a warning about oil level to high and needs to be drained.
isstay is offline
post #17 of 17 (permalink) Old 02-10-2011, 10:11 AM
~BANNED~
Quoted: 4 Post(s)
Only way to fix head gasket is to replace it, hope this is not the case, it is $$$. In my opinion sooner is better, because if it blows trough the oil passage it may cost you even more. Don't know anything about AP4720P0780T, but look at the PDF's that I attached, if this will help you. With small gasket hole car will smoke when is cold more than when warms up (gasket will expand), but eventually will get worse.
isstay is offline
CLS 320CDI Terry Tibbs General Mercedes-Benz 1 08-01-2010 05:18 PM
Burning smell from CLS 320cdi Steve 55 C219 CLS-Class 1 02-23-2009 05:16 PM
My September 05 CLS 320cdi 320CLSman C219 CLS-Class 5 01-12-2006 07:05 PM
My September 05 CLS 320cdi 320CLSman C219 CLS-Class 0 12-24-2005 07:55 AM
Car billows white smoke for 30 minutes after car wash. ketchsailor27 W124 E,CE,D,TD Class 6 05-12-2004 07:41 PM
