If only i could go up a hill... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-24-2011, 03:04 PM Thread Starter
Date registered: Jan 2011
My 2002 ML320 can barely go up a hill.
I figured this was more of a general car problem than model specific, so ill put it in the general forum.
I live in a very hilly area, and going up one, I have to have my foot to the floor to go up to 45mph.
It used to be able to go up decently more. It has about 90 thousand miles. I bought it used at about 30k miles, but I think its still the stock filter.
I purchased a fuel filter, because my mechanic said he thought that that is the problem, but he couldn't replace it due to some health issues.
Do you think this is just the fuel filter? I know the possibilities are catalytic converter, or fuel pump. But those are expensive!
What do you think the problem is? Thanks!
iwishihadamercedes is offline
post #2 of 3 (permalink) Old 01-24-2011, 03:13 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome, please click user cp and add your vehicle and location to your profile, it's useful information.
What do I think the problem is? Your mechanic. Or lack of one. That's like not going to the dentist with a toothache because he's on vacation. When it's important, you get it taken care of.
Cats are a known weak link in several models in that year range. If clogged, they can act just like that. How is your fuel economy? If it is really bad, it's more likely the cats than the fuel filter. That said, however, if you have 90K miles on the original filter, uh, get it changed asap. You're causing an undue strain on the fuel pump, which is more costly as well. There a several possibilities, but why guess on an internet forum? Take it in and get it diagnosed and fixed. You're not saving any money by burying your head in the sand, true?
But find another mechanic. Preferably an indie, and one whose health is not such that he can't work on your truck.
Good luck.
Check Codes is offline
post #3 of 3 (permalink) Old 02-08-2011, 11:07 AM Thread Starter
I figured it out. There is a button below the gas petal, that when hit it shifts down a gear. I just wasnt able to go faster because i was stuck it wasnt shifting down. I should have known this.
    Hill hold renault12ts W210 E-Class 33 02-01-2011 10:49 PM
    Inefficient going down a hill? sranjesuper W201 190-Class 3 03-15-2010 08:42 PM
    Not Accelerating Well Going Up Hill shazanger W123 E,CE,D,CD,TD,TE Class 15 12-13-2009 04:02 PM
    Hill-Billy yoseyman Off-Topic 6 10-16-2007 09:02 PM
    no power up hill only mr diesel W123 E,CE,D,CD,TD,TE Class 3 09-24-2005 07:43 PM
