2004 Mercedes S430 vibration at 60mph and over - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-22-2011, 07:06 PM Thread Starter
Date registered: Jan 2011
Hello everyone,
I am new to this forum and very excited to be here, I am a Mercedes lover and I think its the best car around. I have owned many Mercedes in the past, I am stumped at the current problem I am having. I have a 2004 Mercedes S430 with 89k miles alabaster white with AMG package and 18' original AMG wheels. I noticed a vibration at 60mph and over after i release the gas not when accelerating. I have changed lower control arm, bushing, sway bar link, transmission mount, cheked engine mount and mercedes specialist said they are in good shape, had the tires road force balance, the vibration still there, the mechanic sugested to have the tires balance at high speed with wheels on the car. While doing the high speed balance on the front wheels (the rear could't do it becouse the car has independent traction and the specialist was affraid to do it but did it on the machine) the car was vibrating till the point you could see, after adding the weights there was no visual vibration anymore. I got in the car and start driving on the freeway and same vibration is there, the front passanger seat is vibrating as well. I stoped at my mechanic to explain him that high speed balance didn't do it and what is next? Checked the tires they are in good shape, ball joints good shape, bushings good shape. Now my mechanic tells me that the drive shaft could be out of balance and there is no way to check that than to take it out and send it to do a balance on it. The place he whats to send it is Wenco wich is located in Van Nuys California. Does anybody know about this place?
I'm also afraid that maybe the drve shaft is ok and if we take it down we won't be able to put it in the same place as original.
Please, any info would be appreciated.
Thank you
P.S. in the past I had a 2002 S430 with same problem and could never fix and a 2000 CL500 with same issue never fix
Last edited by Parispresto; 01-22-2011 at 07:23 PM. Reason: I forgot to mention the miles
Parispresto is offline
post #2 of 3 (permalink) Old 01-22-2011, 09:02 PM
eric242340's Avatar
Quoted: 295 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
At the bottom of the page you will find forum jump, click on this and view all the available sub forums.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Possibly the propshaft center bearing.
Regards
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 10-26-2011, 06:48 PM
Date registered: May 2009
Hi, I live near van nuys and I have the same problem with shaking. What happened to you. did you get it fixed. It starts to shake around 55 up to 70 or so. I have not been able to go faster due to traffic. Then when I take my foot off the gas it shakes even more slowing down. The passenger seat shakes and the drivers side mirror shakes. The whole car in the front shakes. I had the wheels balanced and just replaced the other shock absorber and I still have it.
So I am very interest in fixing this. I have a 2000 S500 since it was new.
brianant is offline
    Chassis Vibration at 50-60mph ... jwcinla W140 S-Class 57 03-22-2011 06:10 AM
    Vibration from 45-60mph lhl1 G-Class 5 09-24-2010 11:03 AM
    Does a 2004 mercedes s500 have higher maintenance then the 2004 s430? mdj89 General Mercedes-Benz 5 02-23-2009 03:02 PM
    Vibration at 55-60mph S2K1 W203 C-Class 9 05-01-2007 09:56 PM
    Vibration at 60mph (100 km/h) Antonio G-Class 4 01-13-2002 11:25 AM
