M115 rear main seal leak. - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-21-2011, 01:33 AM Thread Starter
Date registered: Sep 2005
Vehicle: 1970-200 1983-230e
Like the title says...my W123 with a 2.3L M115 seems to have developed a leak from the rear main seal.
I first realized I had a problem when I saw a pool of oil, maybe 4inches across, where I usually park my car...! Checking the oil it was slightly above the low mark... topped it off and kept an eye on the oil-pressure gauge.
Based on the amount of oil on the ground I expected it to get low fast but surprisingly the level dropped quite slowly.. After some messing about I figured that a lot of the oil was pooling in the bell-housing (held there by the forward motion of the car ?) and when I stopped the car puked it out. Strange thing is when I park the car with the engine running it only drips out and the main part of the leak only starts when I shut off. This engine has some high mileage and maybe blowby/crankcase pressure keeps the engine away from the drain hole?
Anyway....the whole car is not really worth the cost of a re-build so I was wondering if removing the upper-sump and just doing the lower half of the seal is worth the effort. I read in a previous post that the drag link has to come off but are there any other problems..? I also thought of unbolting the engine mounts and jacking the engine up a bit,maybe get a few more inches of clearance. Thoughts on this?
anilv is offline
    Oil leak (Rear Main Seal or Oil cooler)???? Tspeerjr W220 S-Class 2 07-01-2009 07:26 PM
    Main seal leak please help Stubudd C208/A208 CLK-Class 5 05-16-2008 05:39 PM
    rear main seal and front pump seal markusfmeyer W126 S,SE,SEC,SEL,SD,SDL Class 1 12-30-2007 08:06 PM
    S600 oil leak. T/C or main seal.both? lesrrt W140 S-Class 9 07-05-2007 12:45 PM
    rear main seal oil leak p100 W123 E,CE,D,CD,TD,TE Class 0 03-06-2007 09:32 PM
