tyre pressure monitering - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-20-2011, 12:22 PM Thread Starter
Date registered: Jan 2007
Post tyre pressure monitering
Hi I have a 2007 e320cdi with tyre pressure monitor which displays the actual pressures on the instrument cluster. Does anyone know if I put winter tyres on wheels without the monitering valves will it show a fault on the dash or just put on the same message as when you first start up i,e TYRE PRESSURE MONITERING ONLY AFTER DRIVING A FEW MINUTES Thanks
steamview is offline
post #2 of 3 (permalink) Old 01-20-2011, 01:07 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
It will put a fault on the dash.
We all have Ford Explorer/Firestone to than for the fact that it's now $400 more to setup a set of spare wheels for winter tires.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 02-23-2011, 08:32 AM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1347 Post(s)
Check with manual or Service Adviser.
There are several types of tire monitoring systems and having different principals they work differently.
I have never seen the factory system on MB in USA, but most common is the sensor attached on inner side of tire valve. Those will stay with the rim when you change the tire, but you better advise the tire person about their presence, or they might be easily damaged.
Kajtek1 is online now
Tyre pressure? njthommo Unimog 4 01-19-2011 10:00 PM
Tyre Pressure mrbig1973 General Mercedes-Benz 0 01-19-2009 12:17 PM
pressure in tyre simas C208/A208 CLK-Class 3 07-07-2008 08:09 PM
Tyre pressure samosali W140 S-Class 4 02-27-2008 07:31 AM
tyre pressure stevepow W126 S,SE,SEC,SEL,SD,SDL Class 10 06-08-2004 01:55 AM
